B16A N/A Monster?
Old Jul 20, 2003 | 02:55 PM
Flu_By_U's Avatar
Default B16A N/A Monster?
Does anyone know what compression ratio and power this engine would have? Also, If something shold be changed or u guys have better ideas let me know I'm always open 4 constructive opinions!
B16A(SiR) w/ GSR Tranny
- LS Crank
- ITR Pistions and Rings
- CTR Rods
- Mugen 2-Layer Head Gasket
- Golden Eagle Sleeves
- DC Sports 4-1 Header
- MSD Wires, SCI, Distributor/ Coil Blaster
- AEM Fuel Rail
- Aeromotive FPR
- Walbro 255lph Fuel Pump
- Toda Lightweight Flywheel
- Clutchmasters Stage 4 Clutch
- ARP Studs and Bolts
- Unorthodox Underdrive Pulley Set
- STR Cam Gears
- Toda Street/Strip Cams
- Toda Valvetrain
- Skunk 2 Intake Manifold
- Skunk 2 ECU
- RPM Service 70mm Throttlebody
- Ported and Polished Head/ Milled .30 over
Old Jul 20, 2003 | 02:58 PM
TEAMGENDAI's Avatar
Default Re: B16A N/A Monster? (Flu_By_U)
Did you cut the counter weights of the crank to fit in the block???? just curious.
Old Jul 20, 2003 | 03:00 PM
nwdave's Avatar
Default Re: B16A N/A Monster? (TEAMGENDAI)
Compression calculator:
http://www.c-speedracing.com/h...c.php
Why would you run a Skunk2 ECU?
Old Jul 20, 2003 | 05:34 PM
B16b2b's Avatar
Default Re: B16A N/A Monster? (delsolguy)
wouldn't your new pistons meet your valves that way?
Old Jul 20, 2003 | 05:53 PM
Mythos EF's Avatar
First I would buy a GSR engine.
Then a 98 + spec ITR gearbox
then think about what it might be lacking other than alot of very expensive Toda engine parts
Old Jul 20, 2003 | 10:02 PM
crazydude75927's Avatar
i might try a civic tranny for its closer ratio and id try a jun or muge ecu and instead of a skunk 2 manifold id try a type r integra manifold. but im a nobody mixed in with a few somebodys so get several opinions.
Old Jul 20, 2003 | 10:22 PM
TwoRedEGgs's Avatar
Default Re: B16A N/A Monster? (crazydude75927)
use a better header, like a hytech, smsp, jdm4-1 allot better than the dc sports !
Old Jul 21, 2003 | 05:13 AM
advanracing62's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Flu_By_U &raquo;</TD></TR><TR><TD CLASS="quote">B16A(SiR) w/ GSR Tranny
- LS Crank
- CTR Rods
- Mugen 2-Layer Head Gasket not worth the $$
- DC Sports 4-1 Header go with Header Tech, SMSP, etc.
- MSD Wires, SCI, Distributor/ Coil Blasteryou don't really need the SCI
- AEM Fuel Rail you don't really need this
- Aeromotive FPR
- Clutchmasters Stage 4 Clutchoverkill?
- STR Cam Gears
- Toda Valvetrain
- Skunk 2 ECU
- Ported and Polished Head/ Milled .30 over be sure to clay the motor if you run big cams
Old Jul 21, 2003 | 06:04 AM
CHEETAH's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Flu_By_U &raquo;</TD></TR><TR><TD CLASS="quote">Does anyone know what compression ratio and power this engine would have? Also, If something shold be changed or u guys have better ideas let me know I'm always open 4 constructive opinions!
- LS Crank
- CTR Rods
- AEM Fuel Rail
- Aeromotive FPR
- STR Cam Gears
- Toda Valvetrain
- Skunk 2 ECU
not enough deck height on the b16a block to use the 89mm crank ... you're confusing it with a b16b block which has the same deck height as a b18c block ... will clear an 87.2mm crank and itr/gsr rods.
also b16a n/a monster would be an 86mm sleeved/bored b16a block with an 8.4cc dome piston ... what you listed is a crappy rod/stroke ratio motor that wont rev too high reliable (even if you found the correct rods to use an 89mm crank).
greg
Th3savinday
Apr 4, 2007 06:24 PM
AllMotor92EG
Jul 1, 2004 12:24 PM
Toda Built
12
Jan 19, 2004 02:19 PM
gsrvx
75
Jun 16, 2003 05:57 PM
Lip
Jun 17, 2002 11:06 AM
