OT: B18C5 9:1 JE pistons vs. B18C1 9:1 JE pistons.....
Old Aug 2, 2001 | 08:24 PM
Blown90hatcH's Avatar
Default OT: B18C5 9:1 JE pistons vs. B18C1 9:1 JE pistons.....
Should I go with the GSR 9:1 JE's? Thanks-JAson
Modified by Blown90hatcH at 8:49 PM 6/8/2006
Old Aug 2, 2001 | 08:38 PM
sgT's Avatar
sgT
Default Re: OT: B18C5 9:1 JE pistons vs. B18C1 9:1 JE pistons..... (Blown90hatcH)
If they are right then they will give you about 9.3:1
but they will work fine
Old Aug 3, 2001 | 07:20 AM
FAST94GSR's Avatar
New User
the compression is different in a gsr because of the smaller combustion chambers in the head. get lower compression pistons for the gsr if you want to be more comfortable like 8.5:1. 26-30lbs that's alot of boost man why so much.
Old Aug 3, 2001 | 09:28 AM
TurboInteg95's Avatar
you would be fine with the pistons you already have. 9.3:1 is hardly a difference.
Old Aug 3, 2001 | 09:47 AM
chri5's Avatar
Default Re: OT: B18C5 9:1 JE pistons vs. B18C1 9:1 JE pistons..... (TurboInteg95)
If you are going to run that much boost I'd get the GSR pistons just for that little extra safety.
btw do you happen to know Nirmal? He used to own a 11 second GSR daily driver.
Old Aug 3, 2001 | 10:05 AM
Turbo EG6's Avatar
New User
Default Re: OT: B18C5 9:1 JE pistons vs. B18C1 9:1 JE pistons..... (Strng1dah)
Na...I just moved here from tampa last year. I think that .3is a big diff on that much boost.
JAson
Old Aug 3, 2001 | 10:54 AM
bigTom's Avatar
Default Re: OT: B18C5 9:1 JE pistons vs. B18C1 9:1 JE pistons..... (Turbo EG6)
id keep them... there is nothing wrong with hi-comp pistons
traumatrix89
Feb 24, 2011 09:02 PM
SpeedDreamz.com
Oct 31, 2009 06:48 AM
bustdgst
Jul 26, 2007 12:28 PM
4dr_GS-R
Nov 18, 2005 12:00 PM
