stripped the T-belt tensioner bolt (mini me)
Old Jul 20, 2003 | 09:38 AM
91civicEX's Avatar
Default stripped the T-belt tensioner bolt (mini me)
i stripped the tensioner bolt. i have a new bolt but i need to get this one out before i put it in. there was a thread on this and this guy said
I found an easier way. Took a flat head screwdriver and slid the timing belt off and then move it 1 tooth that it was off and put a socket on the cam gear and turned it slowly worked perfectly. Dunno how hard it would be to do on a DOHC but SOHC was easy.
he did it without taking the tbelt tensioner off. the problem is i am also putting on a new timing belt with a different number of teeth. and that timing belt could have a different tension.
what do you think? go for it?
ima go get a vise grip from sears and try again
no luck on the vice grip. i put my car back to running order now. should i bring it to a shop to put a new bolt in and not torque it down as much? or should i just grind the head down and try to twist out the bolt by the threads?
Modified by 91civicLX at 7:52 PM 7/20/2003
Modified by 91civicLX at 7:54 PM 7/20/2003
Old Jul 20, 2003 | 11:46 AM
Garrett's Avatar
Do you strip the tensioner bolt or the block?
Old Jul 21, 2003 | 10:35 PM
91civicEX's Avatar
bolt. anyone else who strips any bolt go to sears and get the bolt out thing. it is made by craftsmen and comes with 5 adapters. it took my bolt out with no problems. theres a link to it somewhere in the archives
Old Jul 22, 2003 | 05:53 AM
Ruby Civic's Avatar
Default Re: (91civicLX)
yea, that is what i did and it worked - it was 19.99 at sears, then put a new one in
Old Jul 24, 2003 | 10:18 AM
slowassgsxr750's Avatar
Default Re: (Ruby Civic)
how bad was it stripped,if it barely stripped,and aint rounded off,you can go to autozone and buy valve grinding compound $4,put it on the bolt and socket and loosen it,i know it sounds weird but try it,the compound bonds to the metal
Old Jul 24, 2003 | 06:33 PM
Ruby Civic's Avatar
Default Re: (singleslamrex)
well, so cheap for a new one, just pop for that
clindberg86
29
Jun 26, 2014 08:51 AM
Bignel00
Jun 1, 2007 05:27 PM
Hoosier Daddy
Oct 11, 2003 02:04 AM
b17gsr
Feb 11, 2003 07:46 PM
3rdGteg
Jan 28, 2002 02:54 PM
