1989 Prelude Dual Carb Problem
The problem appears to be the rod between the two carburetors sticking and causing the engine to race, especially after it is hot. Since I bought it (a year ago) it has always had a high idle when cold, but was not a problem once it warmed up. The problem really started a month ago after I returned from two weeks of active duty for the reserves. The first time I drove it, the engine went to redline after driving it for less than a mile. I have taken it to a couple mechanics who tried lubricating it with no luck. Finally, I took it to the Honda dealer who indicated that he could do nothing (it needed new carburetors, and they were not available). I have tried to find used carburetors for it, but they are very hard to find, expensive ($250), sold only as "rebuildable", with no warranty. The car is now idling better than ever when cold (and rod between carburetors returned to proper position), but when hot soon revs up to redline, so that it can't be driven. It won't return to idle without manually turning the "stuck" rod back. I am a college student hoping to get one more year out of my car. If anyone has had experience in this area, and has some advice, please e-mail me. Thank you.
easy fix go buy carb cleaner spray and in tank. Pour the in tank in and take off your air cleaner and spray the inside of the carbs after the engine is warm i.e. choke is off. this should free up the shaft. but if it doesn't go buy some PB blaster and load the shaft and springs up w/ it. and manual rotate the shaft w/ a friend (gas ped). after all is said and done set the timing w/ a timing light and then set the idle w/ the engine up to temp.
Elivi8
Aug 28, 2002 12:15 AM
