Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Water Temp gauge Install Help needed!
Old Jul 20, 2003 | 05:20 AM
VTECAcuraGSR's Avatar
Default Water Temp gauge Install Help needed!
So I bought the adaptor to place the temp sender in the radiator hose and now I am looking at the hoses and Honda is a little wierd. It looks as though the coolant flows from the top rad hose through the block and out the thermostat and through the bottom rad hose back into the radiator. So my assumption is that the sender adaptor needs to go after the thermostat and into the lower rad hose. is this correct? Can anyone confirm this? Thanks!
Old Jul 20, 2003 | 10:18 AM
Victor Penner's Avatar
Default Re: Water Temp gauge Install Help needed! (VTECAcuraGSR)
I made the same assumption this year and cut up a perfectly good silicon hose. You have to put it in the TOP HOSE. I used the little straight section just before the rad. Good Luck!
Victor Penner
Old Jul 20, 2003 | 04:44 PM
Default Re: Water Temp gauge Install Help needed! (Victor Penner)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Victor Penner &raquo;</TD></TR><TR><TD CLASS="quote">I made the same assumption this year and cut up a perfectly good silicon hose. You have to put it in the TOP HOSE. I used the little straight section just before the rad. Good Luck!
Victor Penner</TD></TR></TABLE>
Really? Can anyone deny/confirm? Thanks!
Old Jul 21, 2003 | 10:47 AM
kingrat's Avatar
definitely the top hose
Old Jul 21, 2003 | 01:55 PM
Default Re: Water Temp gauge Install Help needed! (kingrat)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kingrat &raquo;</TD></TR><TR><TD CLASS="quote">definitely the top hose
Thanks guys! maybe its just me but did honda do this backwards? It seems logical that you would put the thermostat on the outflow of coolant not the inflow. No?
PINKS
Mar 12, 2006 12:03 PM
max8455
Jan 10, 2005 05:04 PM
Eyewitness
28
Sep 24, 2003 01:06 PM
gsr98vtec
Feb 11, 2002 05:22 AM
