clutch pros please help me ....
Old Jul 19, 2003 | 10:42 PM
machine4321's Avatar
Default clutch pros please help me ....
did a coulpe runs at the track tonight
first of i put a new clutch in my car about 2 months ago and ive been ******* with it ever since....
now the orig clutch was in ok shape just felt mushy but it alwasy shifted great(except for 3rd of coures)....the new clutch felt great but i cant hit second if i shif fast......i miss 2nd about 4 times tonight ...and over reved of coures cause the stupis spoon chip i have........8500 each time any way car still runs fine but why cant i get it into second .......i put the clutch all the way in and when i shift it just doesnt feel like theres a spot for it ...ive adjusted the pedal for 2 months trying to make it better ..
and after all this it gets hard to put into first.......after a long drive ..like 2 hours the pedal starts to get stiff..i bled the line and flushed it many times
ive got it so it engauges about hlf way up .......please help my motor will be done soon if this keeps up
Old Jul 19, 2003 | 11:05 PM
Default Re: clutch pros please help me .... (machine4321)
it seems im not the only one with the squeaks
https://honda-tech.com/zerothread?id=324835
Old Jul 20, 2003 | 03:45 PM
sigh ...........up
Old Jul 21, 2003 | 06:34 AM
up up
Old Jul 21, 2003 | 07:01 AM
Firedrake's Avatar
Default Re: (machine4321)
What kind of clutch is it? Sounds like it's more of a problem with the tranny than the clutch. Are your shifter cables adjusted correctly?
Also, this is off topic, but why are you shifting at 8500 on a nearly stock H22? Those motors only make power up to about 7000, then start falling off. I bet your car would go faster shifting at 7200 because you'll stay in a better area of the powerband
Brian
Old Jul 21, 2003 | 07:07 AM
Default Re: (Firedrake)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Firedrake &raquo;</TD></TR><TR><TD CLASS="quote">What kind of clutch is it? Sounds like it's more of a problem with the tranny than the clutch. Are your shifter cables adjusted correctly?..
Brian</TD></TR></TABLE>
oh god i would never shift that high by chocie lol im missing second gear cause the clutch wont let me in there .i shift at 7500 or so in 1st and about 7200 for other gears..it just doesnt do squat any higher than that in my car ......and the cables sound like a good place to start.....any baseline adjustments i should look out for ....and where do i adjust them....at the shifter or on the tranny ....
somtimes when i come to a light it has a hard time going into 1st...i have to lift the clutch abit before it engauges and it pops in ????
oh and the disc was exedy and what looked like a reworked PP.....i bought it from this company [url="http://www.bullyclutch.com"] http://www.bullyclutch.com[/url] stage 2 clutch for lude
and thanks for helping out
Modified by machine4321 at 11:18 AM 7/21/2003
Old Jul 21, 2003 | 07:19 AM
BigBlockCRX's Avatar
New User
how is your pedal feel? kinda squishy, or solid? if squishy, you throwout bearing might have a broken leg.. this happens sometimes with a heavy pp.
as for shifting, I would try shifting at a lower rpm, like 7k or 6800rpms. what kind of oil is in your tranny case? try using honda MTL.. maybe your engine is twisting at high rpms and not allowing you to shift smoothly. the cable shift system is sensitive to cable binding.
maybe re-route your cables better, check for binding. just be happy its not going into 2nd from first to 2nd, its better than not going into 4th from 3rd to 2nd!
HTH
Old Jul 21, 2003 | 07:35 AM
well it feels about the same but after i drive for a long time it gets stiff and squishy at the bottom of the pedal travel.....and yes i put the honda mtf in ......and yes my motor mounts are very soft...motor moves a lot ...so thats a good point where is the trowout bearing.....i put a new relase bearing in when i did it ...
Old Aug 2, 2003 | 06:47 PM
up
any other thoughts
mstolars
Nov 29, 2005 07:08 PM
zeroz
Aug 29, 2005 05:16 AM
92BlackSi
28
Oct 25, 2004 02:26 PM
mattL
Jan 13, 2002 01:53 PM
