can you move a wastegate actuator when the vacuum part(the can) is dented?best way to clean charge p
hey guys,i just received a greddy kit from a member here,and packed it really shitty.fins on the type 24 greddy int.cooler are bent from basically wrapping foam material around it 1 or 2 times ,laying on top of the manifold and turbo.i wanted to know if the vaccum can is dented in(on the wastegate),can you move the actuator by hand,to see if it will open and close?can you move it by hand?dont know if thats messed up too.also has some oily pipes(on the outside!)ya'lls best cleaner suggestions will be appreciated.i think i need a
GTEC913
Nov 11, 2007 08:28 PM
Chris F
Jul 23, 2004 03:50 PM
