Tac going crazy
Old Jul 19, 2003 | 05:49 PM
Cre's Avatar
Cre
Default Tac going crazy
My Autometer tac is going crazy. When the car is idling the tac operates as it should. The second you give it gas, it bounces all over the place. I checked all grounds, and connected it to the blue wire at the distrib. This is in an 90 CRX SI
any help would be appriciated.
Thanks,
Old Jul 19, 2003 | 06:08 PM
kanzenr91si's Avatar
Default Re: Tac going crazy (Cre)
is it just the tach or is your motor also skipping around? i have a 91 crx si and i had the needle skipping around on my stock tach and the motor skipped around when i floored it. i ended up changing the ignitor module and it cleared it right up.
Old Jul 19, 2003 | 06:16 PM
Cre's Avatar
Cre
Default Re: Tac going crazy (kanzenr91si)
Its just the tac the motor is running fine. Like i will be around 4k and it will jump from 8 -10k rpms.
Old Jul 19, 2003 | 06:27 PM
Goldfingiz's Avatar
Get a new distributor cap&rotor. About $25 total and very easy to install. My CRX used to do that, but worked like a charm after I replaced the cap/rotor.
Old Jul 19, 2003 | 06:30 PM
Cre's Avatar
Cre
Default Re: Tac going crazy (Goldfingiz)
Awsome I will give that a shot.
Old Jul 19, 2003 | 07:36 PM
slomofo's Avatar
GDD Member
Ground wire, loose distributor bolts, random misfire, or something to that effect. Distributor cap as mentioned earlier could also help.
Old Jul 19, 2003 | 11:10 PM
4crx4me's Avatar
Default Re: Tac going crazy (slomofo)
I just fixed this on my 91 teg. There are three wires that go to the igniter.
It's the brown or black square module on the lower edge of the
dizzy under the rotor.
The wires attach to the igniter with spade connectors.
One or two or all three of those wires need to be pressed in tighter.
You should also put on some Di-electric grease.
And if your tach still goes crazy you might need to crimp the connectors
"GENTLY" with a plier to make them fit tighter.
HTH
Old Jul 23, 2003 | 09:32 PM
Cre's Avatar
Cre
Default Re: Tac going crazy (4crx4me)
Thanks ... This fixed my problem!
Old Jul 23, 2003 | 09:43 PM
4crx4me's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cre &raquo;</TD></TR><TR><TD CLASS="quote">Thanks ... This fixed my problem! </TD></TR></TABLE>
my pleasure, just givin it back, man.
tigueremalo
Jan 28, 2007 11:24 AM
fatboyslim44
May 5, 2004 07:56 PM
hybridbmw
Jul 15, 2002 12:59 PM
JB
Oct 29, 2001 10:29 PM
