Summit RPM switch to activate vtec
Old Jul 19, 2003 | 05:46 PM
Cre's Avatar
Cre
Default Summit RPM switch to activate vtec
Has anyone used one of these to activate their vtec ?
If so how did you wire it up ?
I followed this diagram and mine isnt working!
Old Jul 21, 2003 | 08:15 PM
Cre's Avatar
Cre
Default Re: Summit RPM switch to activate vtec (Cre)
anyone ?
Old Jul 21, 2003 | 08:47 PM
Turbo Powa's Avatar
Try this diagram.
Old Jul 21, 2003 | 08:55 PM
theclutchpoppa's Avatar
Default Re: Summit RPM switch to activate vtec (Panda EK)
both of those are wrong at least im pretty sure they are i had problems hooking up mine too.
Old Jul 21, 2003 | 10:35 PM
91civicDXdude's Avatar
did you make sure to cut the little loops of wire on the rpm activated switch.... those designated 8,6, and 4 cylinder.
Old Jul 22, 2003 | 07:56 AM
Turbo Powa's Avatar
Default Re: (91civicDXdude)
I was just giving an idea. Forgot to mention that I used that one for my EK. My mistake.
Old Jul 22, 2003 | 08:01 AM
Timmah!!'s Avatar
Default Re: (Panda EK)
I would STRONGLY sugest converting to OBD1. I was scewing around with that same swich, in it sucks. Plus you will not have the proper fuel maps, unless you use some type of AFC.
Old Jul 22, 2003 | 08:44 AM
zCivic's Avatar
please correct me if I'm wrong but the Summit switch doesn't have the loops for 4,6,8 cyl. There only for V8's and you have to cut the activation point in half.....like for 5000 you'd use a 2500 activation point etc
Old Jul 22, 2003 | 08:53 AM
EFSiR's Avatar
those are my diagrams and they are correct. They were ripped off my web site....
If you have not noticed, I indicated that in the first one, you need a ground converter. This conversion can be done with my converter or a relay.
The second digram shows how it's done wiht a relay.
Modified by EFSiR at 10:56 AM 7/22/2003
Old Jul 22, 2003 | 09:26 AM
Turbo Powa's Avatar
Default Re: Summit RPM switch to activate vtec (EFSiR)
second diagram was made by me and if i'm correct the top two diagrams were from a mini me swap web page. zCivic you are correct about the vtec point.
Old Jul 22, 2003 | 09:34 AM
zCivic's Avatar
well if thats the case drop the V-tec engagement point to about 2600 and wire a light to it and see if its activating. Thats probablly why its not working if you've got it set to 5200 on a 8cyl its looking to cut on a 10400 on your 4cyl
Old Jul 22, 2003 | 09:36 AM
altoid's Avatar
there are lots of timing changes in the vtec engagement as well as fuel alterations i wouldn't go rpm switch unless you can account for those changes. I've got a bud who makes chips specifically for this purpose pm if you want some info.
Old Jul 22, 2003 | 10:13 AM
altoid's Avatar
Default Re: Summit RPM switch to activate vtec (altoid)
doh nevermind...thats what 3 hours of sleep will get ya
Old Jul 22, 2003 | 10:08 PM
Cre's Avatar
Cre
Yea I have it set to 2600 to come so it will come on at 5200 ? Where can i get that ground converter from ?
Old Jul 23, 2003 | 06:18 PM
JDMCivicEF9's Avatar
Yeah I would like to know more about this swap. i'm helping a friend of mind with his CRX.
Old Jul 23, 2003 | 06:49 PM
zCivic's Avatar
Default Re: Summit RPM switch to activate vtec (JDMCivicEF9)
Dunno about the ''ground converter'' I just used a neg trigger RPM switch and a 30 amp relay. The relay always has the 12volts + and then when the RPM trigger send a signal its a ground- and completes the circuit and make what ever work vtec in this situation.
Old Jul 23, 2003 | 06:50 PM
Turbo Powa's Avatar
Default Re: Summit RPM switch to activate vtec (zCivic)
Ditto.... I did the same...
Old Jul 23, 2003 | 06:59 PM
Sirex's Avatar
Summit rpm activator sucks dick... i had one.. major piece of ****
i have msd now.. works like a charm..
Old Jul 23, 2003 | 07:05 PM
USDM 4G VTEC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zCivic &raquo;</TD></TR><TR><TD CLASS="quote">please correct me if I'm wrong but the Summit switch doesn't have the loops for 4,6,8 cyl. There only for V8's and you have to cut the activation point in half.....like for 5000 you'd use a 2500 activation point etc</TD></TR></TABLE>
i am correcting u
yes it h as the loop cables
u have to cut them both
as for the RPM switch... U use all the cables except the gray oine of the switch. If u get the relay i am going to give the pin outs since the relays are not too explained.
Relay (5 pin or 4 pin one)
87 goes to VTEC solenoid
86 goes to the red on MSD switch
85 goes to yellow on MSD switch
30 goes to a 12V+
and BTW.. really important.. conect that white wire that reads the tach signal to the Neg side of the ignition coil. take the cap off and tap the white cable to the neg terminal. m,aybe thats why isnt kicking 4 u
Old Jul 23, 2003 | 09:31 PM
Cre's Avatar
Cre
I belive i hooked up everything right, I never cut any loop wires inside the RPM switch. Is this required and which ones do I cut (only 2 right)? Thanks for all the help!
Old Jul 24, 2003 | 03:04 AM
Default Re: (Cre)
next to where the cables come off the RPM switch there are 2 lil loops.... i beleive its red and blue.... the switch even comes with heat shrink, so u cut them and wraped them/. look at it... and also like i said check that u getting the RPM signal from the coil
Old Jul 24, 2003 | 06:47 AM
kyle h.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Panda EK &raquo;</TD></TR><TR><TD CLASS="quote">second diagram was made by me and if i'm correct the top two diagrams were from a mini me swap web page. zCivic you are correct about the vtec point. </TD></TR></TABLE>
i think i remember making that diagram for you...
mikester1222
23
Aug 28, 2016 01:34 PM
greddy13
May 16, 2006 06:48 PM
blkhatch92
Nov 29, 2005 11:04 AM
stingray2772
Jan 6, 2003 10:23 AM
project dc2
Dec 24, 2002 06:49 AM
