Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
tighten suspension under load? Or not
Old Jul 19, 2003 | 10:01 AM
globlctzn's Avatar
Default tighten suspension under load? Or not
Hey, I just threw a full gsr suspension/brakes on my eh civic. Should I put the suspension under load before I tourqe all the bolts down? Like on the LCAs and whatnot, someone was telling me the car should be on the ground before I tourqe them to spec. Thanks guys
Old Jul 19, 2003 | 10:12 AM
.RJ's Avatar
.RJ
Default Re: tighten suspension under load? Or not (globlctzn)
i've never done that and never had a problem.
you can use a jack to load your suspension by jacking up the hub if you wish.
Old Jul 19, 2003 | 10:16 AM
globlctzn's Avatar
Default Re: tighten suspension under load? Or not (.RJ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ &raquo;</TD></TR><TR><TD CLASS="quote">i've never done that and never had a problem.
you can use a jack to load your suspension by jacking up the hub if you wish.</TD></TR></TABLE>
Yeah thats exactly what I did, I simulated load with the jack. I just want to make sure before I go pop down $60 bux on an alignment.
ef9itb
Jan 15, 2008 08:51 PM
CivicKid517
Classic Hondas
Nov 26, 2007 04:05 AM
MyEG6
Jul 31, 2005 03:59 PM
