H23 time to Re-Sleeve... or not? #2 & 3 rods snapped
Old Jul 19, 2003 | 08:18 AM
nuc79's Avatar
Default H23 time to Re-Sleeve... or not? #2 & 3 rods snapped
I bought this engine for my accord for $300 w/ harness, ECU, & a severe knock. After taking it apart, the cause was obvious. The #2 and #3 rods snapped. Luckily, neither went through the block. Anyway, they did leave a 1/2" x 1/2" notch on both sides of the bottom of the cylinder sleeves. I already have a set of used replacement pistons, rods, and crank.
My question is:
if the notches are below the lowest travel of the second oil ring, and the engine gets good compression, do I absolutely need to resleeve?
The pictures are below, but they're kind of hard to see since it's not completely disassembled yet.
Old Jul 19, 2003 | 11:05 AM
LudeyKrus's Avatar
I don't see any reason you should have to; the only probs you would have is if it scratched or gouged the cylinders high enough where it'd screw w/ the rings.
Old Jul 19, 2003 | 11:55 AM
BoostedH23a1's Avatar
Default Re: (LudeyKrus)
i wouldnt even play with that block.. start from scratch and do it right
Old Jul 19, 2003 | 12:25 PM
nuc79's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LudeyKrus &raquo;</TD></TR><TR><TD CLASS="quote">I don't see any reason you should have to; the only probs you would have is if it scratched or gouged the cylinders high enough where it'd screw w/ the rings. </TD></TR></TABLE>
sounds good to me. I'm going to assemble it and do a leak-down test. If it looks good, we'll see how it runs...
kaymoto
Sep 7, 2010 05:43 PM
rbeharry
May 15, 2009 09:28 PM
Mo_Spec
May 6, 2005 08:22 PM
dizzyroc88
Mar 13, 2005 05:42 AM
satan_srv
Oct 24, 2002 09:23 PM
