Noise coming from front wheel well
Old Jul 18, 2003 | 02:37 PM
Param's Avatar
Default Noise coming from front wheel well
Hey guys, I'm usually in the prelude forum, but my mom has an accord and its been makin some messed up noises recently. While the car is in motion, it sounds like something is rubbing against the front right wheel well. Its not caused by the engine because when I put it in neutral and rev the engine, i don't hear anything, but simply when the car is in motion. Can anyone help me out with this?????
Old Jul 18, 2003 | 02:38 PM
carolinaACCORD's Avatar
Default Re: Noise coming from front wheel well (Param)
Check the lugnuts, make sure they're torqued down.
Old Jul 18, 2003 | 04:08 PM
Param's Avatar
aright, i'll check those, anything else????
Old Jul 19, 2003 | 08:47 AM
-Bionic-'s Avatar
Former Sponsor
Default Re: (Param)
When was the front brake pads replaced? It sounds as if it's time to change the brake pads, or that you got some dirt stuck between the pads and the rotor.
Old Jul 19, 2003 | 10:08 PM
SIMATIC's Avatar
Default Re: (-Bionic-)
i had dirt in btwn mine, cuz my accord was sittin oin the lot a while...only happened for like a day then went away. Only wen u brake though.
Old Jul 20, 2003 | 06:39 AM
-Bionic-'s Avatar
Former Sponsor
Default Re: (Param)
Hey Param did you figure out the problem?
Old Jul 22, 2003 | 02:25 AM
D114's Avatar
Pull off the front wheels. Look for rub marks on the plastic fenderwells.
check the rotors and brakes and see if they're worn out
come on, its only 8 bolts to check it out.
Old Jul 23, 2003 | 08:21 PM
Param's Avatar
Turned out to be the brakes. It would have been my last guess since I heard the noise even when my foot wasn't on the brakes. Guess you learn something everyday. Anyways, thanks for the help guys
b20acura
Jun 28, 2011 12:20 PM
David12
11
Nov 9, 2009 12:40 PM
sl0wED
May 15, 2004 08:42 PM
Charlie Moua
Jun 30, 2003 02:44 PM
