'92 Interior floods!
I have a problem with water getting into the passenger side footwell after a heavy rain. If i leave the vent off & set the air flow to recycle that usually helps but doesn't stop this from happening.
I was told that there is a drain for rain water near the firewall that may be clogged but I can't this drain to unclog it.
Any ideas? ( I have the factory sevice manual but haven't found any info - if it's in there - what page??)
thanks
thanks
Guest
Posts: n/a
I can not guarentee this, but what might be happening is that water is getting via the vents... kind of like when leaves and dust in the vent system. there is a passage in the passanger footwell for the vent system, and the water could be traveling there. I know when I pulled out my ac system and removed the evaporator and replaced it with the ac delete duct... I get allot more leaves in my system blowing through where the old evap used to catch them all. I don't know how this helps you, but you could take the vent system apart ont eh passanger side and look for clogging
Schu
Schu
This is true. It is coming in the vents - that's why there's got to be a drain (i hope) to keep it from coming in. With the cowl over the wiper linkage removed I can see that there is a slope to direct water from the driver's side to the passenger side, but from there the only thing I can see where it goes is the fan (I can't see the fan, but I can reach it) - but no leaves or dirt get in.
integras are known for leaky windshields as well so take a look
into this as well mainly the leaks are in the corners
but the drain could be cloged as well..
I have not done this myself.
it is probably the little seals that go in the cowl of the windshield. i think there are 8 and they cost just over $2 each. get them, and no worries for a long time. mine are going to be ordered very soon. lol.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MrJasey »</TD></TR><TR><TD CLASS="quote">it is probably the little seals that go in the cowl of the windshield. i think there are 8 and they cost just over $2 each. get them, and no worries for a long time. mine are going to be ordered very soon. lol.</TD></TR></TABLE>
Your right on this. Check out the Teg Tips on http://www.g2ic.com , they have some good info on that problem. I've been meaning to look at my seals too because I sometimes get water down in the passenger foot area also.
DACteg
Jul 27, 2010 11:04 AM
gtowni3
Oct 5, 2004 06:19 PM
