How to strengthen motor mounts....
I keep breaking my drivers side upper motor mount on my 96 civic...It may be my rear mount thats causing it to do that so i gotta change it...But is there any way to strengthen up that drivers side upper mount...Friend of mine said to make a small hole and put some type of poly urethane gel/adhesive in it to make it stronger...Think that would help?..please any info would work...Oh and yes i know some people are gonna say stop being cheap and get motor mounts but i just need an altrenative for now...cash flow is tight if you know what i mean...thanks
If you can find some urethane or window weld to fill the mounts up with that would help im sure. Maybe some Energy Suspension inserts could help you out a little. Of course the obvious choice would be new mounts but if ur tight on cash those are 2 alternatives. Pep boys i know carries the ES inserts...run ya around 40 bucks or so....... I believe. Good luck
Drew
Drew
AllMotorITR
Nov 22, 2001 04:37 PM
