help- wiring diagram for 8 wires coming out of a 2000 civic EX distributor?
Old Jul 18, 2003 | 06:58 AM
owen_the_soyboy's Avatar
Default help- wiring diagram for 8 wires coming out of a 2000 civic EX distributor?
anyone have a wiring diagram for a 2000 civic EX so I can note what the 8 wires are for that are going into the harness? the 8 wires are coming out of the distributor on a 2000 D16Y8 aka EX sohc vtec motor.
At least the 8 wiring colors and what they are for.
I need to get this into a 96 hatch asap and this is the last bit to do... we are going to repin these 8 wires into the 96 dizzy connector that we removed from the 96 dizzy.
thanks in advance
-Owen
Old Jul 18, 2003 | 10:39 AM
Audipwr1's Avatar
Default Re: help- wiring diagram for 8 wires coming out of a 2000 civic EX distributor? (owen_the_soyboy)
owen have you sorted the 12v power, tach signal
then the pairs should be crank posistion sensor
ignitor wire x 2
ground
i had to guess and check with my obd1 dizzy, and it did not damage anything
remember the pairs will have resistance between the two
Modified by Audipwr1 at 7:59 PM 7/18/2003
Old Jul 18, 2003 | 11:16 AM
Default Re: help- wiring diagram for 8 wires coming out of a 2000 civic EX distributor? (Audipwr1)
THANKS!
I got it thru the EG/Civic forum.
Mods, you can delete this if need be.
K PORT
Oct 27, 2009 05:51 PM
owen_the_soyboy
15
Mar 20, 2009 02:56 PM
BlazeInEk
May 3, 2007 07:29 AM
BlazeInEk
Oct 22, 2004 04:08 PM
