Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Alignment for R (autoX)
Old Jul 18, 2003 | 04:03 AM
SlapSmak's Avatar
Default Alignment for R (autoX)
so, went down to my local Tire Kingdom (actually TK Performance, land of much bling), but they have an in ground alignment rack. Got to do the alignment my self, here are the final settings:
FR -1/16" out toe
FL -1/16' out toe
RR 0 toe
LR 0 toe
this is dead on to what everyone has said are the best autoX settings. Has anyone seen accelerated front tie wear for street driving? the car tracks like it is on rails now, litterally 1/2 a mile without touching the steering. Our event got calcelled till next weekend, so havent had a chance to see what it is like between the cones.
Old Jul 18, 2003 | 06:47 AM
.RJ's Avatar
.RJ
Default Re: Alignment for R (SlapSmak)
you wont see adverse wear with these, or even 1/8" toe out per side.
Old Jul 18, 2003 | 07:04 AM
emwavey's Avatar
That's really cool that you had the chance to do the alignment yourself.
I'm set the same in the front except I have a slight toe-in in the back... I read somewhere it helps stability in braking and stuff.
These setting haven't caused any bad wear problems. Though I think camber and tire pressures will more likely dictate how your tires wear.
Old Jul 18, 2003 | 07:11 AM
.RJ's Avatar
.RJ
Default Re: Alignment for R (emwavey)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by emwavey &raquo;</TD></TR><TR><TD CLASS="quote">Though I think camber and tire pressures will more likely dictate how your tires wear.</TD></TR></TABLE>
Toe settings will affect tire wear more than camber any day.
Old Jul 18, 2003 | 08:19 AM
00R101's Avatar
Default Re: Alignment for R (.RJ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ &raquo;</TD></TR><TR><TD CLASS="quote">
Toe settings will affect tire wear more than camber any day.</TD></TR></TABLE>
Actually its the combination of neg camber and neg toe together that starts to accelerate inside wear big time. If you have 2+ degrees neg camber, an 1/8 toe out will produce noticeable wear
Old Jul 18, 2003 | 06:19 PM
VTEConly's Avatar
Default Re: Alignment for R (00R101)
I used to have 1/5-1/4" total toe out in the front with moderate camber (~1.6 deg.) and that was messing up my street tires. 1/8th total toe is NOT the best for auto-x. It is the best setting for street and auto-x before you start doing a number on your tires..
Rob91DA
Northwest
Feb 15, 2011 06:15 AM
JRizEJ6
30
Dec 1, 2006 08:33 PM
Understeer
Suspension & Brakes
Apr 4, 2006 12:13 PM
kcem1
Suspension & Brakes
Dec 15, 2005 01:48 PM
Greyout
Feb 18, 2002 02:35 PM
