Market Research
Not meant to repost, but itr people are more on performence side.
https://honda-tech.com/zerothread?id=566447
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by George Knighton »</TD></TR><TR><TD CLASS="quote">I posted over there, but I'll say the same thing here.
I do not think most of us would pay $200 for a header heat shield that would draw more attention to the header instead of less. If you can get the price down, I'd consider it.
I would consider this:
agreed. my JDM heat sheild works just fine for me...
i, like george, do like the sheild for the oil pan.
like i said in the other post, the header shield will not look shinely like that, so that it will draw less attention.
about the oil pan shield, that was developed for a road racing customer. for more info, call twinsturbo motorsport.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoon_ek9 »</TD></TR><TR><TD CLASS="quote">. for more info, call twinsturbo motorsport.</TD></TR></TABLE>
twinsturbo?
as in Super Tuna TV?
twinsturbo?
Like I said in the other thread as well:
Now, that I <u>would</u> buy. You should market that to the ITR track ****** and ITR H2 racing teams.</TD></TR></TABLE>
George you know Spoon Sports has had a Piece like that that adheres to your Oil Pan for years now, Its only about $30
From Spoon:
"The oil contained in the oil pan is constantly being heated by the exhaust system, which makes it difficult to reduce oil temperature. However, by applying the heat barrier tape to the oil pan, the oil will be shielded from the exhaust heat and oil temperature rise will be prevented. Comes in 200x300mm sheet."
From Spoon:
I've posted this in both threads...
Also as a quick FYI...John at HyTech posted information on this http://www.theoldone.com/forum...HIELD However he chose to not sell this product due to some politics related to the company that he had producing the item for him...
Austin
p.s. My header is coated and there is very little head radiated by the oil pan area, however before the turn under the oil pan there is a fair amount of heat...I'm thinking of adding some Thermo-Tech heat shield barrier to the areas that I'm concerned about, cost $20.
Austin
the soL that could
May 18, 2006 11:20 PM
