window coming loose
Old Jul 17, 2003 | 11:14 PM
hmongboyLS's Avatar
Default window coming loose
anyone ever had a problem with the windows coming loose?... like when you close the door it'll rattle?... my driver's side window is like this... when i close my door you can hear it rattle and when i push on it gently it moves... should i worry about it?
Old Jul 17, 2003 | 11:50 PM
DownBoyDown's Avatar
Hey I just fixed it on my car. What you need to do is pull off the interior panel of the door. Reach your hand inside of the door and you'll probably find a ruber strip that is lying at the bottom of the door. This ruber strip is supposed to guide the window and prevent it from rattling. What you need to do is get some silicon and glue it back in place towards the rear of the door after you slide it back onto the track. If you open up the door you'll see what I meen. When you rwindow rattles while driving when 1/2 way up, is because there is a defective part on your car which there is a recall on. You can fix this by buying the revised part from the Acura dealer, but its around $50 for a little plastic piece unless you car is still under waranty. I didnt think it was worth it so I just decided to put up with it.
makeitwork
Oct 15, 2012 07:37 AM
Kataku2K3
Feb 11, 2007 02:06 PM
MikeMAN
Oct 26, 2002 08:45 AM
yaksplat
Sep 22, 2001 07:21 PM
