window rattle
Old Aug 22, 2001 | 07:34 AM
yaksplat's Avatar
Default window rattle
Anyone else have their windows rattle either when they're just slightly down or when you close the door when they're down?
Old Aug 22, 2001 | 08:13 AM
94acurals's Avatar
Default Re: window rattle (yaksplat)
yep i think everybody in this forum probably has that problem... on g3 tegs at least anyway...
Old Aug 22, 2001 | 08:15 AM
yaksplat's Avatar
Default Re: window rattle (94acurals)
damnit, i was hoping that it's a fixable
i think i still might rip the door apart
Old Aug 22, 2001 | 08:22 AM
94acurals's Avatar
my car got broken into about a week ago. i had a brand new window put in hoping it would stop or lessen the rattle. nope.... rattling away just like before.. lol
Old Aug 22, 2001 | 08:46 AM
E Swift's Avatar
You can't do anything about it. Its just something us Integra owner's must live with.
Its just like domestic owner's have to live with shitty cars.
Old Aug 22, 2001 | 08:50 AM
kento's Avatar
Default Re: window rattle (420TegLS)
my window was rattling badly, and when i closed the door, it sounded like the glass was gonna shatter... i took off the door panel, and the plastic sheet on the door, and low and behold, the left rubber track guide was just sitting at the bottom of my door! I just reworked the rubber guide back in, used some 5 min epoxy on the reverse side of it, and voila... no more rattling window.
Old Aug 22, 2001 | 08:51 AM
E Swift's Avatar
Default Re: window rattle (kento)
Are you serious?????
Old Aug 22, 2001 | 09:00 AM
yaksplat's Avatar
As a mechanical engineer i cannot live with this
but that rubber track thingy makes sense, and today i will not be bored after work
Old Aug 22, 2001 | 09:01 AM
94acurals's Avatar
heh.. me neither
Old Aug 23, 2001 | 04:17 AM
yaksplat's Avatar
That was it, worked like a charm
Thanks man
Old Aug 26, 2001 | 09:05 PM
masterxfob's Avatar
i have the same problem and would like to fix it, but how do i get the door panel off? i know there's the one plastic screw but i don't want to break something when i pull. anything else i should know? thanks
jason
Old Aug 26, 2001 | 11:33 PM
George H's Avatar
Default Re: window rattle (masterxfob)
Yes, you can get in there and tighten things up a bit and the rattling should go away. The easiest thing to do to cure this problem is just to roll the window down far enough to the point where it wont rattle. If you drive with it all the way down, there would be no window rattling problem.
Although I knew about this problem and how everone was facing it before I got my teg surprisingly I have only heard the rattling once in a great while.
Old Aug 27, 2001 | 12:41 AM
LostGsr's Avatar
masterxfob try this site: http://www.team-integra.net/ti/elec/dp-intro.asp
Old Aug 27, 2001 | 12:51 AM
Integ Grl's Avatar
My driver's side window rattled when I closed the door. Luckily, my car was still under warranty, so I had it fixed at the dealer in no time.
Old Aug 27, 2001 | 01:01 AM
masterxfob's Avatar
Default Re: window rattle (Integ_GrL)
wow, that's perfect! thanks lostgsr!
Old Sep 19, 2001 | 04:50 PM
Zulu888's Avatar
where excatly is this bolt/screw that i tighten up?
Old Sep 19, 2001 | 07:38 PM
Erik_Pb_Foot's Avatar
New User
Default Re: window rattle (Zulu888)
sweeeeeeet! i know what i'm doing tomorrow!
(after I figure out how to put my 4 wheeler back together so i can get my car in the garage!)
Old Sep 19, 2001 | 07:47 PM
InfamousRS's Avatar
Default Re: window rattle (Pb_Foot)
I had the same problem with my windows!!!!!!! I felt like I was driving a POS car when I closed my door!!!! It sounded like the window was going to brake when I shut the door. About a week ago I had enough, so I tore my door panel off, at first It looke like someone took the rubber thingy out of the lower window frame that kept the window in place!!!! then I got to looking and that rubber thing was laying in the bottom of my door!!!!! I put it back in, and guess what??? NO MORE RATTLE!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Now I can drive around with my window down without getting mad at the rattle
Old Sep 19, 2001 | 10:22 PM
ALF's Avatar
ALF
Default Re: window rattle (LostGsr)
Hey, thanks for the site! I never knew about it.
Old Sep 20, 2001 | 10:28 AM
betsuni's Avatar
now i have something to do for the weekend. thanks!
Old Sep 20, 2001 | 08:39 PM
G_S_R's Avatar
Default Re: window rattle (betsuni)
just finished fixing mine.
Old Sep 22, 2001 | 07:16 PM
Zulu888's Avatar
Default Re: window rattle (G_S_R)
which bolt is it that i tighten?
Old Sep 22, 2001 | 07:21 PM
Prelussion's Avatar
I guess i'll check on mine tomorrow too!
makeitwork
Oct 15, 2012 07:37 AM
GSRCRXsi
Dec 1, 2004 03:30 PM
hmongboyLS
Jul 17, 2003 11:50 PM
GeorgeY
Mar 28, 2003 12:23 PM
MikeMAN
Oct 26, 2002 08:45 AM
