Can i use radiator hoses as silicone coupling??
Old Jul 17, 2003 | 09:33 PM
2000vsm's Avatar
Default Can i use radiator hoses as silicone coupling??
I think i can find like 2" or so radiator hoses.. can i use those in conjunction with hose clamps for couplings on my charge piping? will it hold or not?
Old Jul 17, 2003 | 09:37 PM
Flamenco-T's Avatar
Default Re: Can i use radiator hoses as silicone coupling?? (2000vsm)
any reason behind it ? I am just curious wether you have no access to silicone coupler or else...
Eventually radiator hose will blow off and silicone coupler are designed for a reason...
I can't stress enough, invest a little extra and be happy in the long run...
Don't take shortcuts....this is an expensive hobby, be prepared...
stan
Old Jul 17, 2003 | 11:53 PM
sporkcrx's Avatar
Default Re: Can i use radiator hoses as silicone coupling?? (Flamenco-T)
On my old turbo set up I ran some radiator hose and it held 5 psi fine.
Old Jul 18, 2003 | 02:06 AM
egg's Avatar
egg
not as a silicone coupling, but im sure you can use it as a rubber coupling
Old Jul 18, 2003 | 08:36 AM
2000vsm's Avatar
Default Re: Can i use radiator hoses as silicone coupling?? (egg)
can i use the stock charge hoses on a 3000gt vr4, some of them are "rubber" or "silcone" but i just know they are not METAL from the stock 3000gt.. can i use those as coupling?
Old Jul 18, 2003 | 08:41 AM
ion_four's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Flamenco-T &raquo;</TD></TR><TR><TD CLASS="quote">any reason behind it ? I am just curious wether you have no access to silicone coupler or else...
stan
So, what makes the silicone hose so much less likely to "blow off"? It attaches in the same manner that a radiator hose would. In addition, radiator hoses are designed to run at 1.1+ BAR all day long at temps in excess of 200*F. I see no problem with this and basically think you are wrong.
Old Jul 18, 2003 | 08:43 AM
rioninja's Avatar
Yes radiator hose will work fine. I good portain of my charge piping is made from large diameter radiator hose. The actual hose will hold upwards of 30psi without problems.
Old Jul 18, 2003 | 10:44 AM
2000vsm's Avatar
Default Re: Can i use radiator hoses as silicone coupling?? (rioninja)
Yeah that's what i was thinking.. radiator hoses hold liquid at around 200F right? and it's under pressure.. and i'm only using it for 7psi.. i think that LOW psi would be fine..
and again, i'm using it as a CONNECTOR, not even a charge piping.. i'll use like 5 clamps on the hose to be safe
so if that works, i assume my "rubber/silicone" charge pipes from the 3000gt vr4 would work then since it's made for 15psi
Old Jul 18, 2003 | 11:43 AM
rioninja's Avatar
1 clamp will suffice.
Old Jul 18, 2003 | 11:55 AM
psileepR's Avatar
New User
Default Re: Can i use radiator hoses as silicone coupling?? (ion_four)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ion_four &raquo;</TD></TR><TR><TD CLASS="quote">
So, what makes the silicone hose so much less likely to "blow off"? It attaches in the same manner that a radiator hose would. In addition, radiator hoses are designed to run at 1.1+ BAR all day long at temps in excess of 200*F. I see no problem with this and basically think you are wrong. </TD></TR></TABLE>
i believe radiator hose is resistant to fuel and oil as well...
silicone hose needs a special insert or it will start to be eaten away
louevilhatch
May 10, 2007 02:46 PM
savedone
Oct 30, 2006 08:00 PM
hybridevul
Jun 16, 2005 07:03 AM
Slvr_CRX
Apr 8, 2004 09:03 AM
B18EG6
May 5, 2003 11:36 PM
