gasket questions
Old Jul 17, 2003 | 08:24 PM
xteg95's Avatar
Default gasket questions
we replacing a headgasket for a b18b1 engine, does anyone know if a headgasket made for a b16 will fit? buddy works at honda and gets them 20 bucks off
also im installing my header on saturday and i guess they dont come w/any gaskets. is it okay to reuse my original header-head gasket w/20k miles, and also is the header-cat gasket the same as the stock one (size wise)...so will it fit around the collector, im assuming i definately need to replace that one...
Old Jul 17, 2003 | 08:28 PM
Moe's Avatar
Moe
Default Re: gasket questions (xteg01)
The header gaskets ususally work, if reused again, but if you have an exhaust leak, you may want to fix that. Or just be like me and not care, and hear a steady put from your car.
As for the headgasket, NO. 1.8l vs 1.6l and im sure they both have different bore sizes, and i know that the alignment dowel's are in different spots on each engine.
Old Jul 17, 2003 | 08:29 PM
xteg95's Avatar
Default Re: gasket questions (Moe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Moe &raquo;</TD></TR><TR><TD CLASS="quote">
As for the headgasket, NO. 1.8l vs 1.6l and im sure they both have different bore sizes, and i know that the alignment dowel's are in different spots on each engine.</TD></TR></TABLE>
alright thats what i figured, what about the header-cat gasket? would a honda OEM one fit my greddy header?
Old Jul 18, 2003 | 11:07 AM
AzG35's Avatar
Actually, they are both the same bore, but some of the dowel pins and oil holes are in different places. So you HAVE to use one for the B18A/B
tpot90
Nov 1, 2010 10:40 PM
zoso
14
Dec 5, 2007 08:37 AM
Saosinx
Jun 27, 2006 12:06 AM
