Will a 1998 Integra Type R ECU OBD2 Fit 96 GSR?
Old Jul 17, 2003 | 08:20 PM
ksilaphet's Avatar
Default Will a 1998 Integra Type R ECU OBD2 Fit 96 GSR?
I wonder if a 1998 Integra Type R ECU OBD2 fit 96 GSR? Will it make any different. Would vtec kick in faster or will it be the same as a regular gsr ecu?
Old Jul 17, 2003 | 08:27 PM
Gee3's Avatar
From: Formerly of SF moved to DFW and now back in SF, CA, USA
Default Re: Will a 1998 Integra Type R ECU OBD2 Fit 96 GSR? (ksilaphet)
I think there might be a problem because the engine setup is different. ie - ITR = sinjgle plenum intake mani, GSR dual plenum intake mani; different VTEC points, etc. I'm sure there's more to it than that but I'd think there would be no benefit or else there'd be a lot more people doing that.
Old Jul 17, 2003 | 08:38 PM
1hotintegra's Avatar
Default Re: Will a 1998 Integra Type R ECU OBD2 Fit 96 GSR? (Gee3)
type-r has no secondaries so if u put the ecu in u wouldnt either
Old Jul 17, 2003 | 09:24 PM
integrasi's Avatar
Default Re: Will a 1998 Integra Type R ECU OBD2 Fit 96 GSR? (1hotintegra)
it will, if you get obd II to obd I wire harness(ex. skunk2 obd1 to obd2 harness)
Old Jul 17, 2003 | 09:33 PM
BLKTEG98's Avatar
New User
I have just added a p73 ecu in to my 98 gsr i have not had any problems at all. Ill add some pics soon
Old Jul 18, 2003 | 11:51 AM
ksilaphet's Avatar
Default Re: Will a 1998 Integra Type R ECU OBD2 Fit 96 GSR? (BLKTEG98)
You didn't any problem with it. So it just fit right in or I have to change any harness or wires.
Old Jul 18, 2003 | 12:07 PM
fergy016's Avatar
to got from obd II to obd I you will have to use a converter harness. obd 2 to obd 1 converter.
seldon
Sep 1, 2008 11:28 PM
xstalkrx
Oct 5, 2003 09:52 AM
CivicFerioSiR
Aug 25, 2003 08:22 AM
iH8RICERZ
Nov 16, 2002 11:35 PM
92TypeR
Oct 28, 2002 12:21 AM
