best injector size for 12:5cr 86mm bore
Old Jul 17, 2003 | 06:56 PM
GOLDENCHILD's Avatar
Default best injector size for 12:5cr 86mm bore
i was wondering if i am safe with rc 370cc injectors in my integra, here is my set up
b18a block
resleeved by golden eagle
arias 86mm 12:5cr pistons
itr head
toda spec b,springs,cam gears,portflow retainers,
and the usual, jdm dc 4-1 header, chipped p28,vafc
any help is very appreciated
thanks
Old Jul 17, 2003 | 11:35 PM
sgT's Avatar
sgT
Default Re: best injector size for 12:5cr 86mm bore (GOLDENCHILD)
440-550cc
Our All motor car is running a setup similar to yours with 440s and its out of fuel.
Old Jul 17, 2003 | 11:45 PM
Default Re: best injector size for 12:5cr 86mm bore (sgT)
the wierdest thing is that with my 370cc injectors i am way rich, so if i get 440cc i will be even richer right? i was going to downgrade to 310cc so i wouldn't be so rich.
what are my options guys?
thanks for the reply SGT
Old Jul 18, 2003 | 06:38 AM
Drag R's Avatar
chipped ecu and 370 injectors, RICH is definately the word!!! u also need hondata.
nick
Old Jul 18, 2003 | 08:58 AM
Default Re: best injector size for 12:5cr 86mm bore (Drag R)
should i get the 100 or 200 from hondata?
Old Jul 18, 2003 | 09:16 AM
Drag R's Avatar
s100 will do it, if you want the extra options; 3step, full throttle shift, etc, then i would go with the s200.
nick
Old Jul 18, 2003 | 07:30 PM
thanks guys. keeping my 370 and getting s200
Old Jul 18, 2003 | 08:04 PM
sgT's Avatar
sgT
go with a larger injector.
440cc
Old Jul 18, 2003 | 09:10 PM
rc told me that 370cc is more than enough for my set up, and this is daily driven, i'm already running way rich.
if i go 440cc then i would be really rich, my idle sucks donkey ***** right now.
Prudz_lude
Jun 5, 2008 11:22 AM
1.8
Jan 4, 2005 04:42 PM
EFb18b
Mar 19, 2004 01:20 PM
hondaspeder
Jun 22, 2003 03:06 PM
V-SPEC 1
Jan 2, 2003 12:57 AM
