neuspeed race
Old Jul 17, 2003 | 06:39 PM
neutron91's Avatar
Default neuspeed race
ive had my 89 crx lowered on neuspeed race with koni yellows for about 7 months... the rear passenger side sits about 1/4" higher than the rear driver side... has anyone else had this problem with neuspeed springs, or any brand of springs for that matter... im thinking about switching springs... most likely progress... its not really that noticeable, but i know it exists and i cant stand it anymore... im very pleased with these springs other than this problem... any feedback is appreciated
Old Jul 17, 2003 | 08:51 PM
DJ_SaNdOz's Avatar
Default Re: neuspeed race (neutron89)
I have the same springs, my car is pretty even. All production cars are allowed variences in parts meaning that not every car or part will have the exact same specs. Cars are made in HUGE quantities & unfortunately manufacturing is not perfect. I would guess that the other componenets in the chasis/suspension may have led to this. unless you have two of the springs in the wrong place
Old Jul 17, 2003 | 10:20 PM
Quik89Si's Avatar
Default Re: neuspeed race (DJ_SaNdOz)
I have similar issues with my Neuspeed sports, although it's more like mine is uneven in both front and rear, and it also tends to sit pretty high in the rear compared to most other CRX's I've seen with the same drop. Skunk2 here I come!
Alex
Old Jul 18, 2003 | 03:44 AM
keithv's Avatar
Default Re: neuspeed race (Quik89Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Quik89Si &raquo;</TD></TR><TR><TD CLASS="quote">Skunk2 here I come!
Alex</TD></TR></TABLE>
alex, i would go with ground control over skunk2. if you want to discuss this further, IM me.
Old Jul 18, 2003 | 06:04 AM
neutron91's Avatar
yeah i was thinking of going the coilover route... but id rather stay with springs if at all possible... i guess ill try the progress springs first and see what happens... if they dont work i guess i have no other choice
Old Jul 18, 2003 | 11:32 AM
scratchline20's Avatar
You may have already checked it but I know when I swapped my springs, one spring wasn't seated all the way on the strut like the others, causing it to sit a tiny bit higher.
Old Jul 18, 2003 | 11:38 AM
misfithamster's Avatar
Default Re: neuspeed race (scratchline20)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by scratchline20 &raquo;</TD></TR><TR><TD CLASS="quote">You may have already checked it but I know when I swapped my springs, one spring wasn't seated all the way on the strut like the others, causing it to sit a tiny bit higher.</TD></TR></TABLE>
yeah that **** happened to me as well as make sure you got those bad boys in there cherry, or itll be a little lop
Old Jul 18, 2003 | 01:08 PM
neutron91's Avatar
yeah ive checked numerous times... the backs fall out of the seat when the car is jacked up... this happened once and it sat alot higher so i noticed and fixed it... so thats not it... ive checked about everything i can think of and still no luck
Old Jul 18, 2003 | 02:50 PM
Are the springs the same height when you put them side by side? Could something like a control arm or trailing arm be bent causing that side to be a little higher? It could have been like that before you put the new springs on and now you just notice it b/c you're looking for it. Crx's sit pretty high stock. It may be hard to notice a 1/4" at stock height. Or maybe the spring just sags a little.
Old Jul 18, 2003 | 07:44 PM
BAZ's Avatar
BAZ
my Eibach sportlines are riding a little high on the rear passenger side too. There is also a clunking noise going over bumps from the same area. Anybody know whats up?
Old Jul 19, 2003 | 06:02 AM
BlameGame's Avatar
Default Re: neuspeed race (BAZ)
I dont think it is the springs, I haave had this issue with all the suspensions that have been on my 2 CRX's...
Blame Game
Old Jul 19, 2003 | 10:20 AM
BAZ's Avatar
BAZ
Default Re: neuspeed race (BlameGame)
could it possibly be a blown strut?
I've got illuminas all around
Old Jul 19, 2003 | 05:16 PM
BAZ's Avatar
BAZ
anyone?
Old Jul 19, 2003 | 10:39 PM
FR-MOB: ThE bEe GuY's Avatar
Mine WAS like that too, but i have the Sprint RX Extremes. I got sick of it so i cut 1 coil off the passenger rear and now its totally even all around
Old Jul 19, 2003 | 11:50 PM
goofball123321's Avatar
If you go with skunk2 go with the integra kit, because these are as stiff if not stiffer than the neuspeed race. I had the neuspeed race, and when i put in Skunk2 civic kit, it was softer, and had more body roll. I went with skunk 2's cause gc's are not as stiff, and I a lot of reviews I read about them, said there was a squeaking noise all the time.
Old Jul 20, 2003 | 10:32 AM
neutron91's Avatar
Default Re: (goofball123321)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by goofball123321 &raquo;</TD></TR><TR><TD CLASS="quote">I went with skunk 2's cause gc's are not as stiff</TD></TR></TABLE>
you can get gc's in any spring rate you want
Old Jul 20, 2003 | 10:40 AM
ThatRicerDaniel's Avatar
Default Re: (neutron89)
cut them .. neuspeeds have alot of dead coils so you can chop alot and still have a good ride.
Old Jul 20, 2003 | 11:54 AM
I was talking about the gc civic kit, but if you can get them at any rate you want then I'd say go for the gc's cause they have a lifetime warrannty. Skunk2 don't have any warranty whatsoever.
slickrc
Aug 1, 2006 09:13 AM
thelarkascend1ng
Feb 9, 2005 06:16 PM
WorldsSlowestEm2
Dec 11, 2003 07:43 PM
crexer
May 4, 2003 09:53 PM
EagleR
Apr 5, 2002 07:48 PM
