HELP! Cleaned engine bay now my car is dead
Old Jul 17, 2003 | 02:55 PM
boondox_saint's Avatar
Default HELP! Cleaned engine bay now my car is dead
I decided to clean my engine bay so i covered the intake, distributor ect with plastic bags and sprayed it down. The car started up fine, but sputtered and died while i was driving, now it wont start at all. any ideas as to whats fucked up??
Old Jul 17, 2003 | 03:06 PM
1 point 6's Avatar
Down Since Day 1
Community Builder
Community Influencer
sounds like spark plugs, or distributor.
PS: Boondock Saints OWNS!!
Old Jul 17, 2003 | 03:09 PM
Quik Chris's Avatar
Default Re: (1 point 6)
Pull your spark plug wires out and look in the spark plug holes. Is there water in there?
976's Avatar
976
New User
Take out spark plugs and let air dry.
Old Jul 17, 2003 | 03:22 PM
Default Re: (Quik Chris)
yeah there was a bit of water in there i took wires out and im letting them dry. the distributor was covered. ill try it agian in a bit
Old Jul 17, 2003 | 03:37 PM
Default Re: (976)
im a moron. its starting up but still must be wet, im letting it dry out more. should i change my plugs after getting them all soaked and drowned out?
Old Jul 17, 2003 | 03:44 PM
SOHC_MShue's Avatar
Default Re: (boondox_saint)
you may want to cover it up a little better next time. I just stuck paper towels in my spark plug holes.
Old Jul 17, 2003 | 03:50 PM
1 point 6's Avatar
Down Since Day 1
Community Builder
Default Re: (SOHC_MShue)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC_MShue &raquo;</TD></TR><TR><TD CLASS="quote">you may want to cover it up a little better next time. I just stuck paper towels in my spark plug holes.</TD></TR></TABLE>
didn that just soak the water up??
Old Jul 17, 2003 | 03:55 PM
SOHC_MShue's Avatar
no it worked fine...oh yea i think i put a piece of duck tape on top of each whole too. I think we just used paper towels, but it may have been plastic baggies...i don't really remember.
Old Jul 17, 2003 | 03:59 PM
good call. That was just the last place i expected to have problems with water
Old Jul 17, 2003 | 04:04 PM
nwdave's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boondox_saint &raquo;</TD></TR><TR><TD CLASS="quote">good call. That was just the last place i expected to have problems with water</TD></TR></TABLE>
Actually, of all the problems I've seen people have with cleaning their bay, it's been water in the spark plug holes.
Don't use so much pressure next time
Old Jul 17, 2003 | 04:06 PM
NrG's Avatar
NrG
Default Re: (delsolguy)
unplug the spark plug that you think has water in it, and crack the engine, water should shoot out.. then let it dry.
i use to presure spray motors for fun, and the car ran fine after that. 120psi water jets makes motor bling bling..
its actually the angel you spray your motor, that will make water ending up in your plugs..
Old Jul 17, 2003 | 04:29 PM
Sketch_hs's Avatar
Default Re: (NrG)
i have always done it by hand, sure it takes longer and you get nice a dirty, but it's a more "complete" job and you don't have to worry about messing **** up...
Old Jul 17, 2003 | 09:19 PM
built562's Avatar
Default Re: (Sketch_hs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sketch_hs &raquo;</TD></TR><TR><TD CLASS="quote">i have always done it by hand, sure it takes longer and you get nice a dirty, but it's a more "complete" job and you don't have to worry about messing **** up...
me too, im to worried about messing **** up, so i cover everything and use a spray degreaser and a brush then small amount of water and a clean rag to rinse, then i spray with cd-2 engine detailer and then let the car heat up at idle and a brand new shiny engine is under the hood
Old Jul 17, 2003 | 10:56 PM
all stock's Avatar
Default Re: (akumaracer)
i goto a coin op car wash place. pretty good and pressured. plus they give u the option of hot water.
Old Jul 17, 2003 | 11:16 PM
SOHC_MShue's Avatar
Default Re: (all stock)
hey man thats a good idea
bk0624
May 24, 2018 02:48 AM
pr0jektdc2
Nov 27, 2004 07:19 PM
pr0jektdc2
Nov 27, 2004 06:42 AM
mr_mbuna
Apr 15, 2003 03:22 AM
is3oo
Jun 26, 2002 10:58 AM
