usdm b16a pistons!?
Old Jul 17, 2003 | 12:49 PM
HmgLauj69's Avatar
Default usdm b16a pistons!?
need some opinion on these pistons...heard that they were a good choice for high comp....i'm planing to get some pistons for my b18b motor (all motor non-vtec).....so throw me some thoughts on these pistons....how much do they usaully run for anyways? will they fit ls rods? will they be to big for the ls block? what's their comp ratio in a ls motor? would it be better if i went with the civic type-r pistons?
Old Jul 17, 2003 | 01:06 PM
mr.beeks's Avatar
Default Re: usdm b16a pistons!? (HmgLauj69)
if you find b16 pistons used you shouldnt pay a lot
and they do fit (minor mods) your LS engine just raising your compresion
but what the heck go for CTR's
Old Jul 17, 2003 | 01:55 PM
HmgLauj69's Avatar
any other thoughts people!?
Old Jul 17, 2003 | 04:28 PM
No-Gi's Avatar
Yoyu could use b16a or b16b pistons. either will bump compression and give you a healthy bump in power. Make sure you get stock bore if you dont plan to OB the block. Do a search
Old Jul 17, 2003 | 06:31 PM
HmgLauj69's Avatar
Default Re: usdm b16a pistons!? (3 South)
yeah i searched but nothing on b16 pistons, how much would used b16a pistons run for? never mind!!! got another question though will the pr3 rods fit a b18b block? hows the clay (the distance between the pr3 pistons and the valves) when installed?
Modified by HmgLauj69 at 3:59 AM 7/18/2003
Old Jul 17, 2003 | 07:30 PM
djay86's Avatar
what are the advantages and disadvantages of running b16 pistons in a LS.
Old Jul 18, 2003 | 12:06 PM
HmgLauj69's Avatar
Default Re: usdm b16a pistons!? (djay86)
higher comperssion ratio
Old Jul 21, 2003 | 06:42 PM
HmgLauj69's Avatar
bump!!!
Old Jul 21, 2003 | 06:47 PM
89civic1.8T's Avatar
This works well in the GSR too right? You shouldn't pay much at all for the pistons. Just make sure they are in really good shape. Find someone who is building there B16A block and offer them 50 bucks for them.
Old Jul 21, 2003 | 07:26 PM
AzG35's Avatar
Default Re: usdm b16a pistons!? (89civic1.8T)
I used them in my Poor Man's Type Arr, work well. 11.1:1 CR, 182hp and 132 torque with GSR cams and mild port work
Old Jul 21, 2003 | 08:16 PM
HmgLauj69's Avatar
coo, thanks
hears to good unexpensive pistons
hbyrd8701
Mar 1, 2010 05:55 AM
92hondaswap
Jul 5, 2008 10:25 AM
girliehonda
Aug 10, 2007 04:08 AM
boostcrx91
May 27, 2007 11:48 AM
89JDMcrx
Oct 22, 2003 05:18 PM
