whats wrong here?
Old Jul 17, 2003 | 12:46 PM
Ronin Panda's Avatar
Default whats wrong here?
89 ef hatch/d16a6/pg7 ecu
the car was wired for the dohc zc...and i was using the pg7 with the zc ...i blew the zc and picked up a d16a6 for temporary use..i put 300 miles on the a6 so far...and all of a sudden theres a 3000rpm rev limit...the motor wont rev past 3000rpm...it cant be because im running a pg7 with a a6 motor because i put 300miles on the motor already and this problem was non-existant...it just started doing this yesterday ...i wiggled some wires at the ecu and under the hood..and it went away ..and then came back again....what could it be?
thanks
Old Jul 17, 2003 | 12:57 PM
DJ_SaNdOz's Avatar
Default Re: whats wrong here? (Touge Panda)
sounds like some kind of connection issue is putting the ECU in limp mode. If you moved some wires & it went away you should check all of the wiring to ensure good connections, etc.
Old Jul 17, 2003 | 01:04 PM
Blaze45's Avatar
Brrraaaap!
Default Re: whats wrong here? (DJ_SaNdOz)
I agree with DJ sounds like one or more of your wires are not connected like they should be. Next time it happens, check the ECU and see what code is putting you in limp mode...
Blaze
Old Jul 17, 2003 | 02:23 PM
thanks guys....yeah i guess ill just go over all my wiring and make sure everythings tip top..and go from there...i bet its a wiring problem.
thanks again.
jager_bomb_79
10
Mar 5, 2010 06:55 PM
b17 turbo
May 7, 2008 11:28 PM
eg6low-buck
20
Mar 17, 2008 06:28 PM
SINISTR
Feb 17, 2008 01:13 PM
zccrx
Apr 1, 2003 08:40 PM
