What rpm will precision sc61 make full boost?
I have a Golden Eagle 84mm gsr block with 9.1 Endyne rollerwaves and mildly ported head with gsr cams and Type-r valvetrain. I was thinking of upgrading the turbo to a Precision sc61 but i would like to know at what rpm i can make full boost.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Charlie Moua »</TD></TR><TR><TD CLASS="quote">I think at about 4k</TD></TR></TABLE>
more like 5k
the common t3/t4e full boosts at 3.5k-4k
more like 5k
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo92Si »</TD></TR><TR><TD CLASS="quote">thanks guys but i need some more opinions before i decide on what to do.</TD></TR></TABLE>
what do you mean decide what to do. get the turbo it will go great with your current setup to make big power
Mine has some boost over 3000, but it doesn't really start to fill up until 5000 and full boost by 5500. This is with 2 3" resonators and a 2 1/2 dynomay muffler, when I run less exhaust it seems to spool about 500 rpm faster.
steve
steve
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by azboy »</TD></TR><TR><TD CLASS="quote">where can I buy an SC61???</TD></TR></TABLE>
IM arturbo.
IM arturbo.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo92Si »</TD></TR><TR><TD CLASS="quote">i don't want a whole lot of lag so thats why i'm not sure if i want to go with the sc61 or just stick with my T3/T4
Just get a smaller turbine wheel and housing. Even though you have alot of displacement you should be fine
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FFgeoff »</TD></TR><TR><TD CLASS="quote">we have some new t3t4 turbos that will blow an sc61 away, for about the same price.</TD></TR></TABLE>
got any dyno proof?
got any dyno proof?
I'm waiting on mine
Well straight T4
I'm waiting on mine
Well straight T4
Wow, those are some pretty confident words!!! Let's see some graphs.
BTW, to answer the question, my sc61 gets full boost, 22psi at 5500rpm. It's an 84mm bore gsr wtih 9:1 compression.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 275Performance »</TD></TR><TR><TD CLASS="quote">
IM arturbo.
id second that , art always answer my questions :D
he gets
from me
IM arturbo.
</TD></TR></TABLE>id second that , art always answer my questions :D
he gets
from me
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by servion »</TD></TR><TR><TD CLASS="quote">Any thoughts on this turbo with a 81mm bore GSR? Will the spool time be drastically increased?</TD></TR></TABLE>
if i've said it once, i've said it a thousand times. Once the 60-1 spools, it doesn't matter what the other guy has. It might not hit right away, but once you get full boost you'll be ghost. And as long as you cross the line first, who cares where boost hits.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by autoEXturbo »</TD></TR><TR><TD CLASS="quote">
if i've said it once, i've said it a thousand times. Once the 60-1 spools, it doesn't matter what the other guy has. It might not hit right away, but once you get full boost you'll be ghost. And as long as you cross the line first, who cares where boost hits.</TD></TR></TABLE>
yes youve said it..but its simply not true...u make like the 60-1 is god..and it isnt
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FFgeoff »</TD></TR><TR><TD CLASS="quote">http://www.full-race.com/turbo/FR63/
more tangential turbine housings than the SC series, t04s housings standard, less shaft play, and it flows more air.
so whats the flow rating on the full race turbo series??and u gonna do a side by side dyno?or at least give us a dyno chart
your a **** talker dude! dont talk **** about a company. Maybe if you were an ethical business man and not a spoiled kid you would realize there is enough buyers out there for you to make money without bad mouthing a company.
personnally i would take a sc61 and a tinker mani over your **** any day.
i've always thought that it was funny how people complained about not making boost till like 5k. I know when i'm racing it never drops below about 4800-5k so it wouldn't really matter. Set the launch control at about 4500k and you don't have to worry about spinning them too bad.
i never used my launch control yet.....how do you go about setting it? And yes i going with an sc61 precision as soon as i can sell my rc's and my T3/T4.
it depends how you have it set up. do you have a digital msd 6 or something with it built in, if so then it's just a little screwtype ****. All my friends have pills or a rpm module selector msd **** that ranges from like 2500-6500 or up.
