Need help with crx problems!!
Old Jul 17, 2003 | 07:37 AM
ElementMotor's Avatar
Default Need help with crx problems!!
Ok, heres the deal. Last week I put different rims and tires on my crx. I went from my HXs with 185/60/14 tires with perfect tread wear and prolly 90% tread on em. I threw on a set of 00 GSR rims with the stock Michilens 195/55/50 with even tread wear there is no inner tire wear from the car being lowered at all on both sets of tires, maybe 40-50% tread is left on the Michilens. Now my car pulls to the left really bad and when I brake the steering wheel tilts to the right really bad. The steering wheel seems to straighten out a little at higher speeds. Oh yeah, and the tires are inflated properly and the tires make squeaking noises sometimes when braking and almost every single time I make a tight turn. What could be causing this?? The car did not pull before with the HXs and it did not tilt the steering wheel under braking.....All I did was put different wheels on it, now the car feels like ***, I can't even stand driving it........Any ideas fella's?????
Modified by EF8 ownz u at 8:52 AM 7/17/2003
Old Jul 17, 2003 | 07:50 AM
SloCivicHMM's Avatar
Default Re: Need help with crx problems!! (EF8 ownz u)
well from what I know....you changed the diameter of the tires and the width....plus the rim is heavier........
GET AN ALIGNMENT! seriously, I have the same problem with my 13in VX wheels to my 15 in Si wheels...even when I changed my azenis to nittos my car acted funny, and still does....
Balance and rotate your tires, get an alignment.......and you'll be set..
Old Jul 17, 2003 | 09:16 AM
CivicEKCP's Avatar
Default Re: Need help with crx problems!! (SlowCivicHmm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SlowCivicHmm &raquo;</TD></TR><TR><TD CLASS="quote">well from what I know....you changed the diameter of the tires and the width....plus the rim is heavier........
Balance and rotate your tires, get an alignment.......and you'll be set..</TD></TR></TABLE>
What he said........I had to!
Old Jul 17, 2003 | 09:18 AM
1 point 6's Avatar
Down Since Day 1
Community Builder
Community Influencer
Im guessing balancing, do they have weights on any of the wheels??
I dont see why he would need an alignment, he changed wheels, not took apart the suspension....but i could be wrong.
Old Jul 17, 2003 | 09:33 AM
Lord Quaalard's Avatar
Default Re: (1 point 6)
Check the tire pressure, it will pull like that when one is low.
Old Jul 17, 2003 | 09:37 AM
Default Re: (Lord Quaalard)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lord Quaalard &raquo;</TD></TR><TR><TD CLASS="quote">Check the tire pressure, it will pull like that when one is low.</TD></TR></TABLE>
Tire pressure is good, checked all 4 wheels......
Old Jul 17, 2003 | 10:16 AM
keithv's Avatar
Default Re: (EF8 ownz u)
fyi, the squealing you hear is b/c those stock michelins suck major ***!
usually the steering wheel will move around more with tires that have a big center groove. this is what people refer to as their tires "follow the road". my kumhos do that REALLY bad.
Old Jul 17, 2003 | 11:00 AM
Default Re: (keithv)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by keithv &raquo;</TD></TR><TR><TD CLASS="quote">fyi, the squealing you hear is b/c those stock michelins suck major ***!
usually the steering wheel will move around more with tires that have a big center groove. this is what people refer to as their tires "follow the road". my kumhos do that REALLY bad.</TD></TR></TABLE>
I agree about the tires being shitty.......other people have told me that too. My car does also "follow the road" a lot more than it did with my HX wheels........
Old Jul 17, 2003 | 11:21 AM
neutron91's Avatar
did you check the pressure with the tires cold?... when your tires are hot the pressure rises about 8psi on average, so say your getting a reading of 32psi when its really more about 24psi... so keep that in mind... and also get the wheels and tires balanced before getting an alignment... its alot cheaper and more than likely the problem, besides the air pressure
Old Jul 17, 2003 | 11:26 AM
keithv's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EF8 ownz u &raquo;</TD></TR><TR><TD CLASS="quote">My car does also "follow the road" a lot more than it did with my HX wheels........</TD></TR></TABLE>
when i had the stock michelins on my 99 teg, i didn't think they followed the road at all. my kumhos definitely follow the road.
maybe b/c you incresed the tire width if feels like the car follows the road??? or in fact it does but its not too much (as compared to other setups)...
i am going to get an alignment on my car very soon. i know i need one so maybe that will reduce the "follow the road" syndrome its got...
Old Jul 17, 2003 | 11:49 AM
4crx4me's Avatar
Just for info purposes there is a FAQ on http://www.tirerack.com
about the "following the road groove" phenomonon. Tire Rack
calls it "tramline" Good info,there.
HTH
EDIT: can't find the FAQ, maybe it was on a flier they sent me. Sorry, everyone. I'll keep looking for the article, though.
Old Jul 18, 2003 | 03:15 AM
keithv's Avatar
Default Re: (4crx4me)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4crx4me &raquo;</TD></TR><TR><TD CLASS="quote">Just for info purposes there is a FAQ on http://www.tirerack.com
HTH
is this the article?
http://www.tirerack.com/tires/...g.htm
i'm going to read it now...
Old Jul 18, 2003 | 03:31 AM
4crx4me's Avatar
i'm going to read it now...</TD></TR></TABLE>
Hey, you found it. Way to go surfing. Thanks Keith,
Old Jul 18, 2003 | 04:02 AM
markleavey's Avatar
I had the same problem when I switched from smaller wheels to larger wheels. Definitely get your wheels / tires aligned and balanced ASAP.
Mark
Old Jul 18, 2003 | 07:16 AM
BAM AM I GOOD OR WHAT??? haha...good luck Chris..
Old Jul 18, 2003 | 09:23 AM
Great article, that explains everything to a T!!
Thanks Keith and Jose who pretty much told me the same thing
Old Jul 18, 2003 | 01:17 PM
anytime *****....
"it never hurts to help" -Eek Da KAT!
apbtwhiskey
21
Sep 16, 2013 05:27 AM
wannaBjdmca6
Sep 22, 2009 06:45 PM
Perfectionist
Sep 3, 2009 04:10 PM
ILS_09
Jul 14, 2009 08:31 PM
Xymox007
Oct 13, 2004 07:39 AM
