35mm Diff Bearings VS 40mm's...
Is the only difference with these bearings, the input diameter (35mm/40mm)...?
I have been trying to find a 40mm quaife for the past 4 weeks (back ordered for at least another month), and have only came accross a couple 35mm's units.
Can I use the 35mm bearings with a 35mm bearing quaife in a 40mm bearing tranny?
Just need confirmation before I order...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bryson »</TD></TR><TR><TD CLASS="quote">Can I use the 35mm bearings with a 35mm bearing quaife in a 40mm bearing tranny?
nope, the 40mm has a larger diameter (81mm i think) and the 35mm is a 72mm (or so) diameter.
check hondaautomotiveparts and you should see the 2 part numbers. look up the a 88+ si tranny (for the 40mm bearing) and a 88-89 dx/hf tranny (for the 35mm bearing).
edit: here is some more info
89 civic si diff bearing
91005-PL3-B04
89 civic si diff shim
41441-PL3-B00 SHIM A (80MM) (1.0)
89 civic dx diff bearing
91005-PL0-008 BEARING (72X35X17) (NTN CORP.)
89 civic dx diff shim
41441-PL3-A00 SHIM A (72MM) (1.0)
</TD></TR></TABLE>nope, the 40mm has a larger diameter (81mm i think) and the 35mm is a 72mm (or so) diameter.
91005-PL3-B04
mgags7
Sep 28, 2005 06:31 AM
rice is nice
May 5, 2005 09:15 AM
bodydropranger
Nov 20, 2003 04:44 AM
