alternator affecting idle?
Old Jul 16, 2003 | 08:20 PM
Behan's Avatar
Default alternator affecting idle?
i have a few Q's about my alternator. The problem: I've had a loping idle since i bought the car in feb. It almost sounds like a misfire, but not as consistent. It is much more prevalent when the car is cold, but still there once the car warms up.
Anyway tonight i discovered it goes away when i turn on the headlights? I drove back to work, and sat there with the headlights on. well when i turned them off the lope got my attention. turned them on, it stopped, turned them off, its back. So i got out the multimeter and checked the voltage at the battery. it ranged from 14.0 to 17.6, it was not consistent at all. Also the jumps in voltage weren't consisitent with the lope. well i then checked the voltage at the alt. and i had a constant 13.9.
why would the voltage not be consisitent at the battery? I turned all the accesories off when i checked, i've also done all the preventitive maintenance, with the exception of timing.
so can any one out there shed some light on this, because i'm stumped.
Old Jul 17, 2003 | 03:33 PM
Behan's Avatar
Default Re: alternator affecting idle? (93preludevtec)
ttt
ballerchild
May 21, 2007 03:52 PM
Chef Andre
16
Jan 12, 2007 04:47 PM
garyc17
Nov 5, 2006 06:26 PM
gsrstyle
Nov 16, 2002 03:47 AM
