Code 4
the best way is to test resistance between d & c terminal on teh connector. if it is between 350-550 ohms then you are ok there so move on to the ground on c & d sperately & if you get resistance that is in teh same range then check teh actual wiring harness. If that is fine then replace dizzy, and/or try another ecu.
