check this intake manifold out
Old Jul 16, 2003 | 11:24 AM
964dgsr's Avatar
Default check this intake manifold out
What do you guys think about this manifold?
http://cgi.ebay.com/ebaymotors...36474
Old Jul 16, 2003 | 11:30 AM
infamousALLMTR's Avatar
Default Re: check this intake manifold out (964dgsr)
gay and cheesy are the first words to mind... then expensive
my 2 cents
Old Jul 16, 2003 | 11:53 AM
letholone's Avatar
that guys a joke.
the guy cant even get a 9 sec licensce, NHRA deemed him UNSAFE to drive, due to his just not being quite "all there".
i've had a few parts from him. the parts work.
but hes a TALKER, and cant back up anything.he'll tell you how every part he has will give you 40 -50 HP.
he is the epitome of fast and furious.
and that manifold is a fuking joke.
Old Jul 16, 2003 | 12:09 PM
RedZone's Avatar
Default Re: (letholone)
It looks like that manifold is for a duel carb set up. a set of Weber DCOE45 side drafts would bolt right up, if so then the manifold should work for that kind of aplication. You could use the new weber throttlebody's which have the same bolt pattern as a DCOE but use Bosch injectors. here is a pic of the throttle bodys that would work with that manifold. The design looks a little cheesy but all in all it should work if looks is not an issue. here is a pic of the throttle body. http://www.gotech.co.za/images...2.jpg
Old Jul 16, 2003 | 12:19 PM
92 civic VX B18c's Avatar
HT Black Ops
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 964dgsr &raquo;</TD></TR><TR><TD CLASS="quote">What do you guys think about this manifold?
http://cgi.ebay.com/ebaymotors...36474</TD></TR></TABLE>
I think there are no bolt hole on the flanges..
Old Jul 16, 2003 | 12:33 PM
this is my favorite part
Made From Space Age Composite Material
Old Jul 16, 2003 | 12:48 PM
HT Black Ops
Default Re: check this intake manifold out (infamousLSVTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by infamousLSVTEC &raquo;</TD></TR><TR><TD CLASS="quote">this is my favorite part
Made From Space Age Composite Material</TD></TR></TABLE>
hehe, the new and imporved Platonuim intake manifold(professional install recomended) will charge your intake with radio active air(May cause cancer) thus improving your combustion charge, ever seen an H-bomb going off? With the correct 10,000.5.1CR pistons you will achieve critcal mass with ever compression stroke! As far as dyno test go , we can never finish one because the electro magnetic pulse turns off the power to the dyno machine,,, ,,,,LOL J/k
I am kidding for all of you who were buying into that, it's a joke!
Old Jul 16, 2003 | 04:36 PM
elude667's Avatar
Expensive, maybe. But if it is made out of a material that doesn't hold heat (whatever that 'space age material' is) it will do just as much good performance wise as a CAI. It's nothing new though, domestic cars have used wooden spacers between the carb and the manifold way back and now they're made out of a phenolic material. Depending on the mounting points of that spacer it might be an easy way to hook up individual throttle bodies. Just my $ worth. The theory behind it is solid but whether or not it flows and what the composition of it is is a different story.
Old Jul 16, 2003 | 08:02 PM
RedZone's Avatar
Default Re: check this intake manifold out (elude667)
I didn't even see it before but the DH-Racing is Dave Hickman Racing....the same guy that tried to make a civic into a spaceship with fiberglass back in 99-2000.......the civic was ugly as hell but moved pretty well.....I think the new one is a bit more normal looking but is chopped in the rear, the rear window is almost nonexistent....
Old Jul 16, 2003 | 10:19 PM
Kidloco51's Avatar
Default Re: check this intake manifold out (RedZone)
uuuhhh, what the hell! HAVE TO LOVE THE EBAY
Old Jul 16, 2003 | 10:33 PM
Trooper's Avatar
Default Re: check this intake manifold out (Kidloco51)
Watch out for the " Ant Eater " lol
Old Jul 17, 2003 | 12:05 PM
indomotor's Avatar
Default Re: check this intake manifold out (Trooper)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Trooper &raquo;</TD></TR><TR><TD CLASS="quote">Watch out for the " Ant Eater " lol</TD></TR></TABLE>
I thought we were the only one calling..that LOL
Old Jul 17, 2003 | 12:14 PM
boostedhb's Avatar
Default Re: check this intake manifold out (indomotor)
Damn that anteater was an ugly *** car. But that manifold just straight out looks nasty. Was up Indo. Car almost done? Mikey
Old Jul 17, 2003 | 10:53 PM
im_poor's Avatar
Default Re: check this intake manifold out (boostedhb)
he has 1000 left, get them while they last
Old Jul 17, 2003 | 11:09 PM
HT Black Ops
Default Re: check this intake manifold out (im_poor)
I bet i could make a bong out of one of those intakes!
Old Jul 18, 2003 | 03:13 AM
Kal's Avatar
Kal
Default Re: check this intake manifold out (92 civic VX B18c)
Old Jul 30, 2003 | 11:43 AM
964dgsr's Avatar
Default Re: check this intake manifold out (kxkal)
Have you guys seen it lately heres updated pics
http://cgi.ebay.com/ebaymotors...09707
Old Jul 30, 2003 | 11:50 AM
arw321's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92 civic VX B18c &raquo;</TD></TR><TR><TD CLASS="quote">I bet i could make a bong out of one of those intakes!</TD></TR></TABLE>
lol best post ever
Old Jul 30, 2003 | 11:52 AM
JaeOne3345's Avatar
Default Re: (RedZone)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RedZone &raquo;</TD></TR><TR><TD CLASS="quote">It looks like that manifold is for a duel carb set up. a set of Weber DCOE45 side drafts would bolt right up, if so then the manifold should work for that kind of aplication. You could use the new weber throttlebody's which have the same bolt pattern as a DCOE but use Bosch injectors. here is a pic of the throttle bodys that would work with that manifold. The design looks a little cheesy but all in all it should work if looks is not an issue. here is a pic of the throttle body. http://www.gotech.co.za/images...2.jpg</TD></TR></TABLE>
thought i was the only one who noticed thats a modded carb manifold.. hehe.
Old Jul 30, 2003 | 04:41 PM
H22ek4's Avatar
Default Re: (JaeOne3345)
the updated picture looks pretty nice.
cjmurillo
Dec 27, 2008 08:40 PM
StolenTeg
Jan 13, 2007 08:18 AM
Charles B.
Feb 18, 2004 11:23 AM
SilverEP3
May 3, 2002 02:43 AM
