whyyy?
Old Jul 16, 2003 | 09:16 AM
89dohcEF's Avatar
Default whyyy?
okay i put a sohc zc into my std hatchback, it runs, but if you rev it high it craps out around 3k, we got the wiring changed over professionally, and the computer is fully functional, code 3 4 and 13 are still running, map sensor, cyl position sensor, and atmospheric sensor
Old Jul 16, 2003 | 09:24 AM
DJ_SaNdOz's Avatar
Default Re: whyyy? (zc_civic91)
fix the codes. who "professionaly" did the wiring? Chances are the wiring is what is causing teh CEL codes & the crappy performance.
Old Jul 16, 2003 | 09:43 AM
markedOO1's Avatar
..igniter? fuel filter?
Old Jul 16, 2003 | 09:47 AM
SCD16A6's Avatar
did you set your tps sensor?that caused mine not to rev all the way when it was first installed.
Old Jul 16, 2003 | 12:00 PM
Blaze45's Avatar
Brrraaaap!
Default Re: (SCD16A6)
Dude your in limp mode. Once you fix the codes you should be able to rev past 3k. Good Luck. If you fix code 3 and 4 you should be able to drive it and rev it to limiter.
Blaze
Old Jul 16, 2003 | 12:11 PM
4drEF's Avatar
Keyboard Humorist
Default Re: (Blaze45)
cyl position sensor - Isn't that the one that you are SUPPOSED to swap the 2 wires around on? From what I have heard, that makes the car not rev past 3k.
Old Jul 16, 2003 | 12:47 PM
DJ_SaNdOz's Avatar
Default Re: (4drEF)
the cylandir position sensor is teh 2 wires from the harness to the front of the valve cover area. the tps sensor will definately hurt performance- i had that code until my sensor was at the correct angle. good luck- i bet it's in the wiring. I was throwing 4 codes until i had my dizzy wiring right & then they went away.
97CWITR
Nov 14, 2011 08:01 PM
360eg6
Oct 27, 2009 09:19 AM
Fatty_1775
Jan 26, 2009 10:00 AM
jus_spooln_wicha
Jun 13, 2007 12:04 PM
cashman38
Aug 15, 2005 09:04 AM
