which steel braided brakes lines to get?
i just got for my eg Integra front brake swap, it came with the knuckles, calipers, rotors etc. but no MC or Brake Booster or prop valve... is this good enough to put on for now until i buy that MC and the other items. also i want to buy Steel Braided Brake lines and im not sure to get it for my civic or for an integra.
Depends....whether or not you want to buy part number 123 or part number 123
Most companies produce the same part for both vehicles.
Goodridge.
Goodridge.
From what I understand read or have been told. Your factory MC, booster and prop valve should work. They help get the pressure to the wheels. that distance hasnt changed so it should be the same. As for the lines I am not sure. If I was you and no one else seems to know exactly, just run down to the junk yard and get some used lines to see what fits the best and just buy that make and model line. I do not recomend using old line from the junk yard. They make look ok from the outside but its the inside that you have to worry about. You cant see the rot or contamination that may have occured for sitting. Good luck.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1 point 6 »</TD></TR><TR><TD CLASS="quote">i used goodridge when i did mine.</TD></TR></TABLE>
Same Here
Same Here
integrawow
Suspension & Brakes
Jun 15, 2010 01:27 AM
Nickb257
May 4, 2010 01:44 AM
