Take out 2nd O2 sensor?
What would happen If i were to take out the secondary o2 sensor from the cat and re-use it as the primary sensor. I recently changed out my primary o2 sensor w/ a del sol unit, and now i'm running hella lean. I'm running a straight pipe, so I have no use for the secondary anyways.
Well, yes it did-- but the thing that I'm worried about is my primary o2 sensor. I interchanged it w/ a Del Sol one, and I think its causing me to run lean-- will changing the secondary sensor w/ the primary sensor be okay?
have u checked ur codes??? the only thing i can think of is ur test pipe....u have to covert to obd1 or get an o2 simulator for that secondary o2...it might be reading lean....when u got ur test pipe done did u still mount the secondary o2 behind the cat?
i want to put on a different cat that doesn't have the secondary o2 also....
had an idea....what if you patch the wires for the secondary into the primary wires?
voltage reported would just go to the same place right?
integranator
Jul 16, 2003 09:46 PM
