Flushing Power Steering Fluid
Old Jul 16, 2003 | 02:04 AM
Jowee's Avatar
Default Flushing Power Steering Fluid
I noticed that the power steering fluid in my R and LS is blacker than my oil and was wondering if you guys knew how to properly flush it.
TIA
Old Jul 16, 2003 | 06:29 AM
JimBlake's Avatar
Default Re: Flushing Power Steering Fluid (ITR 98 1162)
Lift the front wheels off the ground; use jackstands.
Disconnect the hoses to the reservoir, put 'em in a bucket. There's not a lot of room to put a bucket in there so it's a PITA. I haven't figured out how to do this without making a mess. Try the cooler line in front of the radiator.
Start the engine & steer the wheels full lock back & forth a few times to empty out the system. Don't leave the engine running any longer than you have to.
Put it back together & fill it. Start the engine & turn the wheels back & forth. The fluid will be all foamy, so let it settle (20min?) Fill & do it again, until it doesn't foam any more.
If you wanted to use gallons of fluid, you could extend the pump-suction hose to a big bucket of clean fluid, and dump the return fluid instead of putting it back into that bucket. I've never bothered to do it that way.
Old Jul 16, 2003 | 06:23 PM
Jowee's Avatar
Default Re: Flushing Power Steering Fluid (JimBlake)
Thanks bro .
dleccord
Dec 12, 2009 02:21 PM
tegh22
May 12, 2008 12:09 PM
CRXified
Jan 18, 2006 12:38 PM
95TEG
Jun 27, 2005 01:00 PM
arsenal22046
Dec 17, 2004 02:29 PM
