which wiring harness to use for H23 swapped 90 accord??
The car is a 1990 Accord...Which ENGINE wiring harness needs to be used for the car to run. Should we re-use the accord f22 engine wiring or the 94 h23 engine wiring?
The problem is on the H23 it uses a seperate ignition coil whereas the f22 uses the integrated IC and all the h23 plugs do not plug right up to the accord body harness so we are having trouble and was wondering what poeple on here with that swap used for a wiring harness and what mods were needed to the wiring.
accordmaui
Jul 17, 2003 02:04 PM
