Lost Motion Assembly Question
Old Jul 15, 2003 | 09:48 PM
AllmotorJunkie's Avatar
Default Lost Motion Assembly Question
I have a very loud ticking sound coming from my B20 Vtec. The motor is still in the break-in phase with less than 100 miles. We tried doing valve adjustmests but the sound is still there. Another guy suggested my LOST MOTION ASSEMBLY are bad.
1. Does anyone know anything about LMA?
2. What is the LMA purpose?
3. What other symptoms might I look for to be sure it is the LMA that are bad?
4. Know any place I can get ITR for cheaper than $38 a piece?
I searched but did not get any useful info.
Old Jul 15, 2003 | 10:17 PM
xEGxB18Cx's Avatar
The LMAs are there so that while vtec is not engaged the rockerarms dont make the ticking noise, it is like a little dampener for the vtec rocker arm. The only way i know to check if they are bad or not is to pull them out and see if the LMA comes out as one piece or if the top part is already seperated from the rest of the assembly. I have been told that once the top piece becomes detattached from the rest of the assembly the LMA is bad. From the symptoms it sounds like the LMA is shot, what type of head/cam are you running?
Old Jul 15, 2003 | 10:18 PM
xEGxB18Cx's Avatar
my fault read your profile, the older p72 heads have the bad LMA, i hear the newer ones already come with the same units as the type r, i am guessing that those are 96+ heads
Old Jul 15, 2003 | 10:59 PM
Default Re: (xEGxB18Cx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xEGxB18Cx &raquo;</TD></TR><TR><TD CLASS="quote">my fault read your profile, the older p72 heads have the bad LMA, i hear the newer ones already come with the same units as the type r, i am guessing that those are 96+ heads</TD></TR></TABLE>
I read something about that too. Do you think I should replavce them with ITR LMA anyways?
Old Jul 15, 2003 | 11:24 PM
10K2HVN's Avatar
Default Re: (AllmotorJunkie)
try pushing on the them..should be a smooth consistant pressure...
Old Jul 16, 2003 | 01:17 AM
inFamousOneSix's Avatar
Default Re: (10K2HVN)
i got my itr lma's for 135 bucks new on ebay. The guy was sellin a few sets, u should check it out.
Tarmac Junkie
Apr 19, 2012 12:04 PM
blue06civic
Honda Civic (2006 - 2015)
Nov 21, 2007 03:20 AM
B20inDCinLBC
Nov 9, 2006 07:13 AM
LST2
Sep 26, 2005 08:41 AM
AllmotorJunkie
12
Oct 27, 2003 05:11 PM
