which wiring harness to use for H23 swapped 90 accord??
The problem is on the H23 it uses a seperate ignition coil whereas the f22 uses the integrated IC and all the h23 plugs do not plug right up to the accord body harness so we are having trouble and was wondering what poeple on here with that swap used for a wiring harness and what mods were needed to the wiring.
Modified by accordmaui at 8:09 AM 7/17/2003
Use the harness that came with the car. You might have to add plugs/wires as needed but you know the harness will plug right into the car harness.
yea use the accord wiring harness. thats what we used when we did my friends swap h23 in an 1990 accord u do have to add wires/plugs in the harness
accordmaui
Jul 16, 2003 11:24 PM
