Question about converting to OBD-I?
Old Jul 15, 2003 | 06:47 PM
CarbonfiberR's Avatar
Default Question about converting to OBD-I?
Here is my mods: AEM intake, DC header, test pipe, Apexi N1 exhaust, B&M FPR, and ZEX 55-shot kit. My question is, right now my check engine light is on due to the test pipe, I know that going OBD-I will solve that problem but will the new ECU change timing? My concern about the timing is because of the Nitrous. Any info would be greatly appreciated.
Old Jul 15, 2003 | 06:49 PM
Default Re: Question about converting to OBD-I? (CarbonfiberR)
Also I have heard some people say that if the check engine light is on after the test pipe is put on that the car is in limp mode or basically not running correctly is this true?
Old Jul 15, 2003 | 07:39 PM
t's Avatar
t
Changing to an OBD1 ecu will change everything. Fuel, timing, VTEC, Rev limit.
CEL for the secondary O2 will not go into limp mode.
Old Jul 15, 2003 | 09:16 PM
vtec.dc2's Avatar
you could custom tune that obd1 ecu - hondata in my case - if tuned right, it will take care of all issues.. or.. just run a cat.. it doesn't hurt much.. really..
Old Jul 16, 2003 | 10:11 AM
JICB16B's Avatar
if you want the check engine light to go out remove the 2nd o2 sensor from the cat and plug out the hole in the test pipe with a old o2. Take the 2nd o2 and tie it up somewhere under the car i the open that way the computer will think that the cat is working perfect. Good luck
Old Jul 16, 2003 | 06:10 PM
t's Avatar
t
Default Re: Question about converting to OBD-I? (2kB16B)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2kB16B &raquo;</TD></TR><TR><TD CLASS="quote">if you want the check engine light to go out remove the 2nd o2 sensor from the cat </TD></TR></TABLE>
You should not have a CEL if you are running a cat
and plug out the hole in the test pipe with a old o2. Take the 2nd o2 and tie it up somewhere under the car i the open that way the computer will think that the cat is working perfect. Good luck</TD></TR></TABLE>
Why waste an expensive O2, when you could just use the correct sized bolt? But hey, its yours and you can do anything you want.
Old Jul 17, 2003 | 06:59 PM
Default Re: Question about converting to OBD-I? (t)
I understand about the light that is not my concern. My concern is I am trying to squeeze more power out of my car and going OBD-I will help me in the long run incase I do cams or internals. Of course in the meanwhile I also want to be safe with the Nitrous and advancing the timing is not a good thing. With Hondata is it completely tunable as to where I can leave timing as it is and not adjust it?
Old Jul 18, 2003 | 03:57 AM
SlapSmak's Avatar
Hondata is completely tunable. fuel curve and ignition maps. I have heard that the tieing up of the O2 works, but my test pipe does not kick a cel. Mine is an 00R. I usually only run my SMSP cat, the test pipe occasionally, but with no light.
rbdynamics
Dec 15, 2005 05:46 AM
Dai_Ca_Vietnam_H22a4
May 21, 2005 08:42 PM
ImporttRacerr555
Dec 6, 2003 10:02 PM
Adampops
Dec 21, 2001 11:23 AM
canuckr
Sep 24, 2001 12:12 PM
