AEM EMS or Hondata?
Old Jul 15, 2003 | 06:10 PM
NXAccordTO4B's Avatar
Default AEM EMS or Hondata?
I need help picking one or the other..... pro and cons
thanks
setup:
f22b1 (11:1) built motor all except for sleeves
fmax turbo kit with t3/t04e
rc550
HKS boost controller and turbo timer
Full MSD
Fuel pump, rail, pressure reg, etc...
and a bunch of turbo related stuff.... don't feel like typing them all
Old Jul 15, 2003 | 06:22 PM
3700 Vtec's Avatar
Default Re: AEM EMS or Hondata? (NXAccordTO4B)
I've heard good stuff about Hondata, it's a good deal cheaper then the AEM EMS if you go without all the extras.
Old Jul 15, 2003 | 06:39 PM
Crono139's Avatar
Hondata is perfectly fine for what you have. Hondata is in the range of $200-$500, depending on what system you want. AEM EMS is around $1300, or so.
Old Jul 15, 2003 | 08:35 PM
Broken Gearbox's Avatar
Default Re: AEM EMS or Hondata? (Crono139)
there both good F.M. but i would personally go with a Hondata.
Old Jul 15, 2003 | 10:51 PM
KTeller8's Avatar
Default Re: AEM EMS or Hondata? (James.)
i am going hondata
and i have access to the Aem at a discounted price, still feel hondata is way to go, unless your super douper modddd and boosting crazy #
Old Jul 15, 2003 | 11:15 PM
DLB1994's Avatar
Default Re: AEM EMS or Hondata? (KTeller8)
am a hondata fan ,i have it with 756cc injectors and 3bar map and car drives like stock
Old Jul 16, 2003 | 09:40 PM
Default Re: AEM EMS or Hondata? (DLB1994)
my hondata setup would run me about 1600 since i have a obdII car. I need the p28 with harness with boost. I have alot of mods in the car. So i think i need the tuning however............ im really stuck trying to pick one. They will cost about the same.
Old Jul 17, 2003 | 06:40 AM
KTeller8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NXAccordTO4B &raquo;</TD></TR><TR><TD CLASS="quote">my hondata setup would run me about 1600 since i have a obdII car. I need the p28 with harness with boost. I have alot of mods in the car. So i think i need the tuning however............ im really stuck trying to pick one. They will cost about the same.
who is waxing you dry?
how you get 1600 for hondata?
its the same cost plus a harness: 150-180 bucks on top
i am obd2 and its not that hard:
Old Jul 18, 2003 | 08:48 PM
i wanted all the extra crap.... data logging etc..... im just going by what the price is on the website.....
Old Jul 18, 2003 | 11:12 PM
KTeller8's Avatar
find a dealer: they can offer you better prices: They get them at discount and can pass the savings to you
Old Jul 18, 2003 | 11:58 PM
Shtryfe's Avatar
Even if your accord is pre-OBDII wouldnt you have to get a Different ECU still. Also, Im kinda curious why if the AEM EMS is better for a heavy modded car with boost, wouldnt running high compression with boost be considered crazy enough for it, ive never had experience with either yet, just trying to learn alittle, correct me if im mistaken.
Old Jul 19, 2003 | 04:50 AM
KTeller8's Avatar
Default Re: (Shtryfe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Shtryfe &raquo;</TD></TR><TR><TD CLASS="quote">Even if your accord is pre-OBDII wouldnt you have to get a Different ECU still. Also, Im kinda curious why if the AEM EMS is better for a heavy modded car with boost, wouldnt running high compression with boost be considered crazy enough for it, ive never had experience with either yet, just trying to learn alittle, correct me if im mistaken.</TD></TR></TABLE>
Yes with honda you have to chip a P28 bout a 150 dollar cost:
But if your pusshing high boost on the accord you better not have high compression, you should have already redid the block FOR turbo
Old Jul 19, 2003 | 07:05 PM
BoostedH23a1's Avatar
Default Re: (KTeller8)
**** hondata in the ***
if u had a civic or teg sure hondata.. but accord preludes i reccomend ems
ive been through 3 p72 ecus in the past 3 months..
no problems in the wiring harness. i could have bought 2 ems by now
Old Jul 19, 2003 | 07:11 PM
DLB1994's Avatar
Default Re: (BoostedH23a1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoostedH23a1 &raquo;</TD></TR><TR><TD CLASS="quote">**** hondata in the ***
no problems in the wiring harness. i could have bought 2 ems by now</TD></TR></TABLE>
i have a p06 ecu and i have no problems with it hondata gets a from me
you wanted to keep them dumb secondaries
Old Jul 19, 2003 | 08:23 PM
Default Re: (DLB1994)
... still deciding..... half says hondata the other half says ems
Old Jul 19, 2003 | 08:39 PM
NathanMorris's Avatar
Default Re: (NXAccordTO4B)
hondata.
Old Jul 20, 2003 | 08:49 AM
dabrown's Avatar
Sorry, I do not mean to kill the thrill but I am trying to buy a hondata for a basic setup and the cheapest I have found with tuning is $1000. The Hondata is not so appealing to me anymore! The problem is the availability of tuners is limited in my state (2). So I guess they can charge what they want.. So I don't think the price should affect the decision. How do they compare in features and ease of use would be the main concern.
Old Jul 20, 2003 | 10:03 AM
booja's Avatar
11:1 comp. is pretty high for turbo
Old Jul 20, 2003 | 10:38 AM
Lost Type R's Avatar
Default Re: (booja)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by booja &raquo;</TD></TR><TR><TD CLASS="quote">11:1 comp. is pretty high for turbo</TD></TR></TABLE>
not really, people go with a setup of high compression and low boost as long as its tuned and done right.
Old Jul 20, 2003 | 11:01 AM
KTeller8's Avatar
Default Re: (Lost Type R)
AEM still needs Tuning
either one will need them; just not plug go:
as far as the other guy: why you runnign p72's
no point? P28 care good enough:
Old Jul 20, 2003 | 11:32 AM
turbochic's Avatar
...Doing a search on handata, and came across this topic... so i'll just comment on why i would like to go hondata.....
The thing that i like about Hondata is that it still uses the stock ecu from honda, it lets you keep the things that has made honda so great in the first place.
if you go aem ems then you are basicly get rid of everything and going with another companies idea and set up, now dont get me wrong i think either one is good. I have also heard that the aem ems is easier for the users to tune. the hondata takes a more experienced tuner.
i am not to the point where i can feel comfortable tuning it myself so for me hondata would be fine.
...good luck on your decision
Old Jul 21, 2003 | 12:22 AM
GimpyAccord's Avatar
Default Re: (fmaxturbochic)
Hondata sucks, nuff said. I'm not saying I like the EMS either, but I DOES seem pretty slick! Its like a baby motec and they keep adding things everyday to it. The one big thing it does have over using a stock honda ECU is the fact it can handle more than 4 injectors. Now you coudl hack in more injector drivers to a honda ecu, but you're talking way more work than its worth IMO.
Hondata used/continues to use quite a few incorrect formulas on certain items. Not to mention they're staffed by a bunch of tools and totally screwed a lot of the stage 2/3/4/4b customers with the s100/200 upgrade etc.
All I'm going to say is if you do your research and you're on the ball you can accomplish the same thing they do for free.... or near free. If you're not so much on the ball I really would sway you towards an EMS. I know a few people running them with great success now and it didnt take a rocket scientist to make it happen.
I think what bothers me most about Hondata is their insistance to keep tunes available only to the dealers. EMS users tend to share configuations and AEM encourges this as well. I'm not saying you should still tune on the dyno with/without help, but its nice to know you can get the thing up & running easy and without bribing a dealer.
Old Jul 21, 2003 | 01:13 PM
Default Re: (GimpyAccord)
wow, i thank everybody for there input.... hopefully i will make the right decision.... however i guess being that both system are good.... there is no wrong choice.......
Old Jul 21, 2003 | 08:54 PM
ApexiAccord's Avatar
hope yall dont get mad for me posting but i have a brand new AEM Ems forsale if you are interested. brand new in the box never been used. my friend was suppose to put it in his accord but he got into a bad wreck which was not a normal accident. but any how hes selling it so he can pay for his hospital bill . the price is $1200 shipped and i have people to vouch for me if you are interested.
pm me or email me at STR8PLAYAMADE@HOTMAIL.COM
Old Jul 21, 2003 | 11:21 PM
Spunkster's Avatar
Default Re: AEM EMS or Hondata? (dabrown)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dabrown &raquo;</TD></TR><TR><TD CLASS="quote">Sorry, I do not mean to kill the thrill but I am trying to buy a hondata for a basic setup and the cheapest I have found with tuning is $1000. The Hondata is not so appealing to me anymore! The problem is the availability of tuners is limited in my state (2). So I guess they can charge what they want.. So I don't think the price should affect the decision. How do they compare in features and ease of use would be the main concern.</TD></TR></TABLE>
Have you checked on tuning costs for the EMS? IT usually takes about 3 times as long to tune, so expect it to cost even more.
