Yet another a/f and boost gauge question...
Old Jul 15, 2003 | 04:07 PM
braintree's Avatar
Default Yet another a/f and boost gauge question...
I just purchased a set of used autometer boost and a/f gauges however, the wires are rather short. Is there a certain gauge wire that I should use to extend it or does it really matter? Also, the boost gauge's power and ground wire are larger so I am assuming I will need a thicker gauge wire than the a/f gauge(if that makes sense ). Thanks in advance for any help.
Old Jul 15, 2003 | 04:49 PM
drjondurst's Avatar
I was wondering the same thing.. I have a a/f gauge with single strand small small wires (dont know the exact size). Will it matter if I use a slightly bigger multi-strand wire to extend them?
Not trying to thread-jack, our questions are pretty much the same thing.
Old Jul 15, 2003 | 06:14 PM
braintree's Avatar
Default Re: Yet another a/f and boost gauge question... (braintree)
Holy Jebus, this forum moves fast. TTT
Old Jul 15, 2003 | 06:42 PM
boostedcivicsir's Avatar
Mr. Badwrench
led's are low current, so thick wire isnt necessary. but if it is all that you have, its ok.
Old Jul 15, 2003 | 07:04 PM
braintree's Avatar
Default Re: Yet another a/f and boost gauge question... (boostedcivicsir)
I guess what i'm really worried about is the o2 signal wire for the a/f gauge. IS it a special kind or can I just get the same size wire to run it?
Old Jul 15, 2003 | 07:06 PM
Mr. Badwrench
i think the wire off the gauge is like 20 or 22 ga. i have 16 ga lying around and used it. worked fine you should be ok.
Old Jul 15, 2003 | 07:13 PM
braintree's Avatar
Sounds good. Thanks for taking the time to answer my questions.
Old Jul 15, 2003 | 08:46 PM
NuclearB18B's Avatar
i used 16 gauge for the civic...never had any problems
Old Jul 16, 2003 | 12:20 AM
_Endless_'s Avatar
you can use automotive wire like those of engine harness. your local autoshop or performance shop may have them.
potatostix
Mar 30, 2006 10:02 PM
Voodooboy520
Dec 3, 2005 03:59 PM
C-Zero
May 9, 2004 05:33 AM
mrlegoman
Feb 3, 2003 04:15 PM
