tipsīn tricks for better track times!?
Old Aug 1, 2001 | 10:33 AM
austrian type-R's Avatar
Default tipsīn tricks for better track times!?
Hey guys!
Can you tell me some tricksīn secrets to get better times for the 1/4 mile acceleration. Iīll put my stock 15" rims with 205/50/15 back on. Tire-pressure on hot days, cold days? ....remove stereo.....donīt wheel spin....?????
Tell me something, I know you have some secrets, USA is the DRAG-land!!!!
Old Aug 1, 2001 | 10:34 AM
D's Avatar
D
Default Re: tipsīn tricks for better track times!? (austrian ITR)
yeah, removing that stereo will definatly help a ton....
D
Old Aug 1, 2001 | 10:45 AM
Ross's Avatar
25 Year Member
Community Builder
Community Influencer
Active Streak: 30 Days
Default Re: tipsīn tricks for better track times!? (D)
Maybe he's got a few subwoofers back there. If so, def. remove them. take out the spare tire and fiddle with your tire pressures.
Old Aug 1, 2001 | 12:15 PM
itrhybrid's Avatar
Practice, practice practice. Time will definitelt help you. Also where are you shifting?
James
Old Aug 1, 2001 | 12:39 PM
CheezeFrog's Avatar
Hey bro,
If you're a guy, just disgregard this because you already know better. But just in case you're a girl, here's some tips:
1. release the parking brake before you race. Actually, remember to release it before you leave for the track.
2. Turn the a/c off.
3. Take all the beanie babies, articles of clothes, CD's, and makeup and at least put them in the trunk, if not remove them from the car before you go to the track.
4. Let the engine wind out to redline (or if you're good, near fuel cut). You don't have to short shift at 4K RPM all the time.
5. Even though you might get your hands a little "icky", pop the hood before your run and let the engine cool down.
Good luck, and happy racing.
Old Aug 1, 2001 | 12:40 PM
AWDSOME's Avatar
Default Re: tipsīn tricks for better track times!? (CheezeFrog)
I Posted these tips in another recent thread:
https://honda-tech.com/zerothread?id=54974
Best tips:
1. Lower front tire pressure to 21 PSI. If you want also increase the tire pressure in the rear.
2. Work on shifting faster ( alot of people lose time by shifting to slow)
3. In the beginning don't worry about a perfect reaction time of .500. The clock doesn't start ticking till you begin rolling. Instead focus on lauching the car. After you get your launches down then go for the .5XX reaction times (in other words start at the third yellow).
4. Don't trust your tachometer if it is stock. I rev mine till about an indicated 8800RPM. You will probably hit you limiter the first time you try, but it is Ok just remember where the needle was when you hit the limiter for next time and shift right before it).
5. Launches vary, but lately I have had a lot of success launching around 4.5K. Before I used to have to ride the clutch a little more or I would spin to much.
6. If you are going to drag alot invest in motor mount inserts ($30). They will stop your front end from hopping so much. It will not help your 60' time, but it will save you some very bad hopping and excessive abuse.
Good luck!
The Holy Molar
Apr 28, 2012 10:47 PM
patriot
Oct 23, 2008 02:00 PM
junbb1
Apr 30, 2006 06:02 PM
DsITR
Apr 23, 2005 11:29 AM
Ohlias
Apr 26, 2002 05:47 AM
