got my car weighed today
Me and my boy 743motorsport went to get my car weighed today. I had FULL interior, full gsr suspension front and rear, b-series motor.
As far as weight reduction, I have no A/c, or ps, no drivers side airbag, and replaced exhaust manifold with a header. Here's some pics:
The pics suck *** because they are taken from video clips I took today.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Si.Hatch.92 »</TD></TR><TR><TD CLASS="quote">Not bad...Were you the guy with the white one that got stolen?
If so, nice car to make up for her
Yea, that's me.
It's a cx.
No, I don't weigh 500lbs. I'm less than 180.
</TD></TR></TABLE>Yea, that's me.
It's a cx.
nice, just as a heads up a 99 civic si rim/wheel centercap will fit perfectly in the hole in your sparco wheel, then the sparco anodized aluminum ring will bolt over the centercap and it looks really tight and professional, the centercap is like a polished aluminum look with a black
in the center, 20$ i think, the sparco ring is like 15$.
thanks i have 4 laying here from the stolen hatch<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by euclid »</TD></TR><TR><TD CLASS="quote">nice, just as a heads up a 99 civic si rim/wheel centercap will fit perfectly in the hole in your sparco wheel, then the sparco anodized aluminum ring will bolt over the centercap and it looks really tight and professional, the centercap is like a polished aluminum look with a black
in the center, 20$ i think, the sparco ring is like 15$. </TD></TR></TABLE>
i'd post pics but i cant afford to buy a camera. must... buy... car... parts...only</TD></TR></TABLE>
said something like that to my girlfriend, haha not workin to well
I just tried it, but it doesnt work with my quick release hub. Good idea though. I can't even fit the sparco horn button in there, so I drilled a hole in the left spoke and made a button.
in the center, 20$ i think, the sparco ring is like 15$. </TD></TR></TABLE>I just tried it, but it doesnt work with my quick release hub. Good idea though. I can't even fit the sparco horn button in there, so I drilled a hole in the left spoke and made a button.
well if you want to get crazy i used a handpeice to bore out a 1cm hole in the centercap to fit the red sparco horn button. it fits in between the 2 sides of the
nicely.
also, i have the 2" spacer and the centercap wouldnt seat all the way either so i grinded about 2mm off the back of it, i grinded off the little clips basically. but i am quite literally insane when it comes to diy **** like that.
nicely.also, i have the 2" spacer and the centercap wouldnt seat all the way either so i grinded about 2mm off the back of it, i grinded off the little clips basically. but i am quite literally insane when it comes to diy **** like that.
Capt. Jimbo McSubipants
Dec 6, 2006 04:46 AM
Collateral
Mar 28, 2005 07:09 PM
