How in the Fawk do you remove the manual window crank in a 97 dx?I searched.
I'm sorry, but I can not figure out how to get the manual window crank off right now. I did a bunch of searches for window crank, window handle and etc. and kind find anything on 6t gens. I'm going to get my moldings repainted and can't get the damn window crank off. Any help asap would be extrememly appreciated. Thanks.
There is a clip holding it on, just run a towel behind the handle. Or, push the door panel in, pull out a little on the crank handle, and pull the clip out with some small needlenose pliers. Or, go to Advance and waste your money on their special window crank handle clip removing tool. Hope this helps.
on all manual window cranks on hondas there is a small weird c shaped clip. if you use a small screw driver pry in between the base of the crank handle and the door trim panel you'll be able to see the clip. you need to pull it out with a small hook tool/awl. once out you can take the handle off. hope that helps.
The towel trick sounds good, I never heard of that one. I just push it out with a screwdriver.
SWEET!!Thanks a million guys!
I've been scratching my head so much I have a sore spot. J/K. Thanks.
B18cHatch06
Jul 18, 2007 08:36 PM
okman16
26
Nov 9, 2003 12:48 PM
Mentat Ghola
Jan 11, 2003 04:47 PM
