quick question on halo headlight hookup
Could someone give me some instructions on how to wire the halo to the parking light wires? i have a negative wire and a positive where do i wire them to? ive been trying for hours but i havent had any luck. thanks
just run those wires to the corner light bulb harness. there should be three wires on the corner light harness. the black is obviously ground and i believe the wire that is not striped is the positive. make sure you d/c the batterry first before you start splicing cuz you might slip and blow a fuse or more. good luck
thanks...could you tell me where the parking light harness is and what it looks like and how do you splice a wire?? thanks for the help. what i was trying to do was take the wire from the halo and go directly into the parking light wire but i guess you have to go into the harness right? i think i know how to splice but im not sure could you tell me im not good with wiring. thanks
Modified by HoNdAeX11 at 11:09 AM 7/15/2003
i cant find the corner light bulb harness is it the thing the bulb is hooked up to or is it further back the wire toward the back of the engine bay?
do i need a resistor on the end of the positive and i read somewhere maybe i want a parallel connector to the parking lights what is all this stuff and how do i do it???
yes its the connector that connects to the bulb... if its only two wires then thats easier cuz its only power and ground. just tap into each wire by stripping the cover off the wire or you can go to radio shack and get some wire taps. just tell the guy what your trying to do and he'll know or at least he should know. just remember to d/c the battery since this is your first time cuz you might short circuit the system. make sure you match the black to black and then the red wire will go to the remaining wire. get it? good luck
mikecp
Jan 20, 2020 02:19 PM
hondamagic98
Sep 5, 2003 10:03 AM
