b20 turbo puffing smoke
Old Jul 15, 2003 | 05:59 AM
Will Albers's Avatar
Default **UPDATED** b20 turbo puffing smoke now with comp#s
I have a stock b20 turboed via a greddy kit. Its intercooled, running a zdyne gold, walbro pump, and 440 injectors. I run it at 10 psi and barely ever go over 6k rpms.
However it has started smoking oil. It started only when i would shift, now its especially bad when i let off of teh pedal.
I yanked the plugs and took some photos, does it look like a ring/valve problem to you? Or did i fubar the turbo possibly?
(if the photos do not work, please let me know)
from left to right, 4 3 2 1
4 and 3
2 and 1
Close up of 2 and 1
Modified by Will Albers at 9:01 PM 7/21/2003
Old Jul 15, 2003 | 06:09 AM
Patch's Avatar
Default Re: b20 turbo puffing smoke (Will Albers)
Hard to tell by plugs alone. Do a compression test and tell us the results.
Old Jul 15, 2003 | 06:18 AM
Charlie Moua's Avatar
well it your Zdyne GOLD tunned?
I seem that your running a lot more richer than normal. Are you sure that it's a cloud of black smoke and not grayish/white?
Did you put too much oil in the motor, causing some oil to slip past the rings and enter the cc?
Old Jul 15, 2003 | 06:25 AM
I would guess my tune for the zdyne is rather crude. I have never been able to find a reliable b20 tune. It has worked for a few months rather decently. I have built the tune off of a stock pr4 tune
Im confident that it is a blue smoke and it smells like oil. Im just wondering if its the turbo.
Old Jul 15, 2003 | 06:57 AM
turbochic's Avatar
i would say an easy way to test if its the turbo could be to take off the downpipe and see if there is oil, or oil residue, thats what i had to do for mine
Old Jul 21, 2003 | 11:59 AM
Did compression check and #1 and #3 = 185. #2 and #4 = 195. What does that tell me? Should i look into the turbo?
Old Jul 21, 2003 | 05:23 PM
turbochic's Avatar
yeah i would, those are the exact signs i had, like i said take off the down pipe, you can tell FOR SURE that if there is oil in that area, it is definately your turbo
Old Jul 21, 2003 | 08:35 PM
Blaze45's Avatar
Brrraaaap!
Default Re: b20 turbo puffing smoke (fmaxturbochic)
The pictures dont work for me.... Take off the DP and see if there is oil residue...
Blaze
Old Jul 22, 2003 | 12:33 PM
turbochic's Avatar
Default Re: b20 turbo puffing smoke (Blaze45)
so did you take off the downpipe or find anything else out???
got an update???
sleeponef
Dec 17, 2010 12:45 PM
vestalfootball72
Dec 11, 2007 07:58 AM
B20turbo85
Dec 18, 2006 05:08 PM
95 RED CIVIC
May 3, 2006 05:01 AM
JalopySiR
Dec 6, 2002 09:24 PM
