FS: Hotlap Timer Standard w/o Transmitter
Slightly used Hotlap In-Car Timer. Comes with standard display, receiver, data cord, and even batteries, but NOT transmitter! (wont work without transmitter of course but most track events theres usually someone else with a transmitter already setup) Condition is almost perfect except for two holes on the back of the display used for mounting, otherwise no scratches.
Product info:
An infra-red transmitter mounted at trackside automatically triggers the In-Car Timer with 100% accuracy each and every lap - no 'thumb' errors. Use the Double Range transmitter where access to the edge of the track is limited. Standard transmitter works up to 60 feet.
Drivers see your lap times as they happen
Adjust your driving line to find the fastest time
Easy to install & remove
60 lap memory with easy recall
Transmitter can be mounted inside or outside track (not included in this model)
Cost $150 obo NEW $198
IM me if interested.
Product info:
Longacre and some others sell a pushbutton (~$30) that will plug into the display that you can manually hit to time yourself if no transmitter is at the track. I use this setup and it seems to work pretty well since I do not have a transmitter.
andrew dc
May 26, 2004 08:18 AM
Austin
Dec 9, 2002 04:40 PM
Austin
Dec 9, 2002 03:14 PM
