VAFC Hack | 450 cc Injectors
Old Jul 14, 2003 | 11:50 PM
Turbo-JC's Avatar
Default VAFC Hack | 450 cc Injectors
Since I got my ride everyone has been pushin' me to do this.
I want to get on the DYNO to see what my mixture is first - but what does this exactly require ? From what I can tell, 450 cc injector's which I can pick up used for 100 + , a V-AFC which is about 200 - 300 usually , having my injectors checked for safety , 25 each injector = 100 bucks, anything else?
Down to business, it seems that the settings are already well known and can be copied from the net - is this true? Seems sorta strange because there are obviously many different setups out there.
In the end, do you even need to run larger injectors with my setup or do this big charade, or maybe just get new stock injectors being that mine are 150K old . ? I've been told that injectors don't truly need to be upgraded unless your horsepower gets in the 200 range, well I'm probably not pushing more than 130 to the ground... sorta wondering if this would be worth my cash ?
Any help? Thanks
Old Jul 15, 2003 | 05:57 PM
-Racer X-
Guest
Posts: n/a
Default Re: VAFC Hack | 450 cc Injectors (Turbo-JC)
get a b series motor and call it a day.
Old Jul 15, 2003 | 06:03 PM
bladesilver's Avatar
You want an S-AFC. V-AFC is only for people with VTEC like me.
Old Jul 15, 2003 | 07:11 PM
dfoxengr's Avatar
try 50 for used 450s, and 25 total to flow test. afc for about 175 used. and then u realize you dont need it for an NA motor.
Old Jul 17, 2003 | 01:48 AM
Turbo-JC's Avatar
Default Re: VAFC Hack | 450 cc Injectors (hybridvteceg)
I was told it is 25.00 per injector ? Guess I was told wrong or ?
Wow...no one can answer my questions on here huh?
Old Jul 17, 2003 | 09:52 AM
drifter57's Avatar
$100 for 4 dsm 450 injectors is fair
Old Jul 17, 2003 | 11:12 AM
Turbo-JC's Avatar
Default Re: VAFC Hack | 450 cc Injectors (drifter57)
ayt.
cxVtecC1
Oct 8, 2004 09:08 PM
jeremy.
Oct 18, 2003 10:36 AM
SlamMan
Jun 9, 2003 08:53 PM
Big Josh
Apr 2, 2003 09:50 AM
aemciv
Feb 26, 2003 11:31 AM
